Boost Tables in ATR
I took some 4th gear WOT logs today and confirmed that my MAP is logging 18 to 19 psi. My targets are currently set for 16 psi so I am assuming that my WG duty cycles are too high. Also, I didn't get my RPMs where I wanted to. I need to find a better road or do this in 3rd next time...
- Attachments
The past few weeks I have been making adjustments to my map in ATR and I noticed that the only way to really control boost is with the load tables and the WG duty cycle table. You also have to adjust both or you will get nowhere. The boost target tables are basically irrelevant from what I have seen.
Users browsing this forum: No registered users and 146 guests
