Something stinks....
JROD
Postby JROD » Wed Oct 08, 2008 9:14
Hey All,
I kinda have a dumb issue and wanted to see if anyone else has experienced the same thing or something similar. In the morning (or when the car has been sitting at least 8-12 hours) when I start my car and let it run for about a minute, a weird smell starts coming from under the hood (not from the exhaust). The closest thing that I can compare it to is like woman's nail polish (although slightly different). It only does it for a brief second upon a cold start up and then goes away after about a minute or two. It never did it until about a week ago even though I've had the car for about 8 months now. I have looked and there is no smoke or anything like that... the car runs perfect, but the smell is awful. Not really concerned at this point, just annoyed.
Car is a 2008 MS3 with about 5K miles on it.
Any thoughts/ideas on what it may be?
Postby dommo_g » Wed Oct 08, 2008 9:14
Did your girl spill some nail polish on the engine while adding washer fluid? :dunno:
Postby RX-7 Chris » Thu Oct 09, 2008 9:14
you might want to check and see if a plasic bag got stuck under there or something like that.
JROD
Postby JROD » Fri Oct 10, 2008 9:14
RX-7 Chris wrote:you might want to check and see if a plasic bag got stuck under there or something like that.
I thought about that too and quickly glanced, but figured if it was a bag or something like that, it would stink all the time not just for a minute or two.
CWPMS3
Postby CWPMS3 » Fri Oct 10, 2008 9:14
My 8.5 MS3 did this for a while also. All that I could put it up to was the heat shields warming up and outgassing chemicals from their composition. I currently live in PHX,AZ. and with all the summer heat it slowly faded away.
Zwetty
Postby Zwetty » Wed Oct 22, 2008 9:14
I think I've smelt the same thing, also can't quite describe the smell as it comes through the vents. Smells like a burning though. Mine does it most if I gun it reverse a little. I smelt it again when I was Bandimere doing a test and tune a couple weeks ago too. I've got an 08.5, everything seems just fine (and no plastic bags either).
Postby iani1.1 » Wed Oct 22, 2008 9:14
i had the same smell from my fc a couple weeks ago. i know its weird, but when i was trying to fix my rear wiper, one of the wires were burnt. might wanna check the wires jus in case
Users browsing this forum: Baidu [Spider], Bing [Bot] and 9 guests
