New - Local information please...
Dange
Postby Dange » Thu Jul 21, 2011 9:14
hey no problem. well most these kits ARE carb legal. greddy. ffs,, begi. which means they will be legal in all 50 states.
the 1600 turbo kit comes with minor fueling. i believe it just has a rising rate fuel pressure regulator. to be honest. realizing how much the price went up, you would be better off getting this. its alot better kit and upgrades alot easier. allthough not carb legal.
as long as you have a good cat and you didnt go under the hood and tear out all your emissions stuff. you should be fine.
if you ever plan on living in cali, your options are limited.
04MSMGT
generalfred
Postby generalfred » Fri Jul 22, 2011 9:14
Well, I just picked up a '90 Miata with 87K mi on it... It's mint. Has all the tasteful mods... 15' wheels and tires, sway bars, stress bar (rear only), shocks and springs.... I bought it in CoS.. the drive back was great. Super stoked!
I find it revs a little quicker than some of the others I've driven, although the engine, intake, and exhaust are all stock... Still pretty slow though esp. at this altitude.
I plan to turbo it, but I'll probably wait until spring... until then, intake and header will have to do. OBX was suggested. I had planned on Raceland, but after reading it seems that their about the same quality, with OBX being cheaper. As for an intake, I have no ideas, and am open to any suggestions. I'd like to stay on the cheaper side... It'll all have to go when turbo time comes.
Dange
Postby Dange » Sat Jul 23, 2011 9:14
cheaper side.
get you one of these
i ran one of these for a long time. works just fine. next step up is the racing-beat style. (89 bucks) and the best is the randall cowl intake.
04MSMGT
dsm_luck
Postby dsm_luck » Sat Jul 23, 2011 9:14
Dange wrote:engine is basically the same as the 323GTX a factory turbocharged engine. so the engine loves boost. your rods are good up to 250whp pistons should be good for 30-50 over that. the reason its not a higher boost set up is you need fueling and an ecu to go past that level.
i wouldn't worry too much about getting near the 200hp range. ive been running at around 225 for almost a year now.
Thats fantastic. I bet the little car rips with numbers like that.
