Gtx3071
COSpeed3
Gtx3071
Postby COSpeed3 » Mon Oct 24, 2011 9:14
Getting ready to place a order:
ATP GTX3071 without turbine housing
ATP EWG Housing
ATP Oil/Coolant Line Kit
ATP Dump Pipe
Tial MVS Wastegate
Has anyone put one of these things together?
Cobb–Access PORT
Cork Sport-FMIC,Intake,Inlet
Edge-Insight CS Scan Tool
Innovate-LC1 Wideband Gauge
Luminics-Fog,High Beams
RPM-Vent Pod
Turbo Smart-Dual Port BOV
Turbo XS-TBE[/SIZE]
Dange
Postby Dange » Mon Oct 24, 2011 9:14
from my understanding if you can take off the stock turbo and put it back on you can do it with the ATP. iirc its direct bolt on.
04MSMGT
COSpeed3
Dange wrote:from my understanding if you can take off the stock turbo and put it back on you can do it with the ATP. iirc its direct bolt on.
from what i understand is that yes the IWG turbo is a direct bolt on. but im going with EWG and think the kit comes in 6 pieces???
Cobb–Access PORT
RPM-Vent Pod
Turbo XS-TBE[/SIZE]
dsm_luck
Postby dsm_luck » Mon Oct 24, 2011 9:14
COSpeed3 wrote:from what i understand is that yes the IWG turbo is a direct bolt on. but im going with EWG and think the kit comes in 6 pieces???
I did my gt3076 install by myself with a friend to lend a hand in a few places. You will need to have a dump tube fabbed up. Its a tough install but all atp turbos for this car are bolt in. If u have any questions or need help let me know.
COSpeed3
Postby COSpeed3 » Tue Oct 25, 2011 9:14
dsm_luck wrote:I did my gt3076 install by myself with a friend to lend a hand in a few places. You will need to have a dump tube fabbed up. Its a tough install but all atp turbos for this car are bolt in. If u have any questions or need help let me know.
I know the turbo it self will bolt in but im not sure about the EWG Housing, Oil/Coolant Lines,Dump Pipe and Wastegate. I dont think its going to come put together. im going thur JP@EAS and has the dump pipe on my order but it still needs to be fabbed? Where did you get your tuning done at? Are you also running EWG? do you like the set up? anything you would change about it?
Cobb–Access PORT
RPM-Vent Pod
Turbo XS-TBE[/SIZE]
RichB
Postby RichB » Tue Oct 25, 2011 9:14
Where'd you order from?
dsm_luck
Postby dsm_luck » Tue Oct 25, 2011 9:14
COSpeed3 wrote:I know the turbo it self will bolt in but im not sure about the EWG Housing, Oil/Coolant Lines,Dump Pipe and Wastegate. I dont think its going to come put together. im going thur JP@EAS and has the dump pipe on my order but it still needs to be fabbed? Where did you get your tuning done at? Are you also running EWG? do you like the set up? anything you would change about it?
The EWG housing is on the hotside of the turbocharger. If the turbo is coming in different pieces it will need to be put together. Other than that everything is a direct bolt on lines and all. There is one coolant line that needs a longer section of rubber hose to fit. I used a same diameter fuel line for it. It takes a good chunk of time to do the install. You need to set aside a weekend in case you run into problems. The hardest part was getting the turbo out of the actual car because its tight back there. The dump pipe should be fine but I have heard of people running into issues with the dump pipe hitting aftermarket down pipes.
I did all my tuning myself. Took an OTS Cobb map and modified it for the 3076. Put down 407 whp and 395 wtq at 23 psi on a weak tune. Tuned on 75% E85 and 25 psi now and I would assume its 15-25 hp more with a ton of torque. Turbo is IWG on stock manifold and MAF.
JP is actually the guy that lent a hand. Hes a good guy and his prices rock.
dsm_luck
RichB wrote:Where'd you order from?
http://stores.edgeautosport.com/StoreFront.bok
RichB
Thanks!
I don't see some of the stuff on your list on the website so I am assuming you called.....
dsm_luck
RichB wrote:Thanks!
JP can get you anything you need just call him.
I got my turbo through him as well.
RichB
sweet.
What's the dump tube look like and where does it exit? I would definitely want to go EWG but the fab that is needed for the dump tube worries me. The only way I can think of getting it done is to drive to a shop after I install the turbo w/o hitting boost to get one fabbed up. Since I have a hard time staying out of boost, this isn't ideal.
COSpeed3
dsm_luck wrote:The EWG housing is on the hotside of the turbocharger. If the turbo is coming in different pieces it will need to be put together. Other than that everything is a direct bolt on lines and all. There is one coolant line that needs a longer section of rubber hose to fit. I used a same diameter fuel line for it. It takes a good chunk of time to do the install. You need to set aside a weekend in case you run into problems. The hardest part was getting the turbo out of the actual car because its tight back there. The dump pipe should be fine but I have heard of people running into issues with the dump pipe hitting aftermarket down pipes.
what r u running for ur inlet?
Yes, JP has some great prices...
Cobb–Access PORT
RPM-Vent Pod
Turbo XS-TBE[/SIZE]
COSpeed3
dsm_luck wrote:JP can get you anything you need just call him.
Rich u can PM JP on here for better prices then his website:
http://www.coloradomazdaclub.com/forums/member.php?u=1262
or u can try here also
http://www.mazdaspeedforums.org/forum/members/jp-edgeautosport-com/
He can get anything u what
Cobb–Access PORT
RPM-Vent Pod
Turbo XS-TBE[/SIZE]
COSpeed3
RichB wrote:sweet.
Dump pipe looks like this:
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=TP&Product_Code=ATP-MDP-025&Category_Code=
Cobb–Access PORT
RPM-Vent Pod
Turbo XS-TBE[/SIZE]
RichB
COSpeed3 wrote:Rich u can PM JP on here for better prices then his website:
Awesome!
Users browsing this forum: No registered users and 237 guests
