and currently ready to be cleared. should look like this (on passenger side)once cleared.
Shadowden wrote:Did you do any sanding before you polished? Will there be enough for the clear to adhere to?
Looks great. What will you be using for clear?
Shadowden wrote:Yeah, it seams all CF, with the exception of dry CF, does it eventually. Not sure why.
Given the surface area of the hood and the application using a rattle can (I presume), I would probably not wet sand, but I would go after it with a fairly aggressive polishing compound and work to a nice fine finish. I would be afraid of burning through your clear coat when wet sanding, even though you are doing it by hand.
Your car looks great, by the way. Nice work on the hood.
jdmsp wrote:Thanks! And I went out and purchased an air compressor, cheap air gun, and clear lacquer by duplicolor so I'm not worried about burning through I put like 4 light coats on and seems thick enough for wet sanding.
