My name is Brent. I was a mechanic at one time, but now I buy and sell cars for myself.
Here is my mod thread. Nothing special, just some minor mods.
http://www.rx7club.com/build-threads-292/94-rx7-1069753/
thanks!RX-7 Chris wrote:Welcome
thanks, I will check into that. Is there a guide to resetting the idle? I've pieced things together from the Internet, but haven't found anything fully dedicated. When I did the tps, I set the idle screw under the intake to a half turn from closed. Ps: I have not removed anything from this vehicle, other than the AST and stock exhaust.Dwduc wrote:Welcome. That idle stuff does seem weird. Do you still have AWS and did you check out the dash pot adjustment. I would also try to reset the Idle. It is possible that the cold idle is having to make too many IAC steps to keep alive.
speedjunkie wrote:Welcome!
Sounds like you're on the right track to reset idle. The air bleed screw is supposed to be set half a turn from closed, just like you did, and the screw on the front and the one on the back next to TPS should just barely be not touching the linkage wheels or whatever they're called lol.
Number2 wrote:Welcome to Boulder
