Fixer upers - car almost "good" to go
christi
Postby christi » Thu Feb 17, 2011 9:14
Sorry for the groan. My hands are frozen. No we haven't. **** Mazda and their poor design with putting the third brake line at the bottom. I'm still in the springs. The biotech won't thread on to the cylinder.
christi
Postby christi » Fri Feb 18, 2011 9:14
We got it tighten but the pedal still goes to the effing ground. WTF. I think we are gonna drive the car to Parker on the back roads (black forest) and bleed the lines tomorrow morning. Three hours to do this - did you know the turbo model FCs do not have three brake lines - why would Mazda do such a snooty design?!
christi
I drove the car back last night and she drove alright. The brakes work - they feel softer than I'm used to. Soon as I officially wake up I'll be changing my pads. Atleast she's partly happy :p
christi
Postby christi » Sun Feb 20, 2011 9:14
So, the only thing I really need to do is the MAF sensor cleaning..... but I'm stupid, and haven't figured out how to clean it properly?
The brakes aren't bad, really. They're 100% in top shape when I was going to change them tonight.... The only thing that's poor on them is/are the rotors. The left rear is warped on some spots, causing the vibration.... and I think I have too much rear bias(?) as to why my rears lock up fairly fast when stopping pretty hard... Shouldn't the fronts lock up first?
Also - when bleeding the brakes today ... my rears were pretty much gray/brown color... Pretty disgusting if you ask me.
I'll be making a secondary thread.. for my modifications I plan on doing to the car... like some input none the less :)
Postby RX-7 Chris » Mon Feb 21, 2011 9:14
to clean the MAF:
Pull the whole unit and spray it down with MAF cleaner inside and out. Just make sure you use a real MAF cleaner. Very easy.
I would keep working fluid through the brakes. make sure it is completely clear. It would be best to replace all the fluid with new.
christi
Postby christi » Mon Feb 21, 2011 9:14
Chris - I did a full bleed brake last night. Pictures of the front and rear brake fluid ;)
http://yfrog.com/h4re0ubj
http://yfrog.com/hsfc7nsj
Also ,when I take apart the MAF again, I'll take a photo of that disconnected wire. I'm still curious *where* it is to be. I also found another disconnected wire near the BMC & 3rd brake line when changing it out on Friday.
christi
Postby christi » Mon Feb 28, 2011 9:14
So, as some of you know, I replaced my cat on Sunday. She runs perfectly, loud and backfirey :D However, I've ran into a issue. I'm not sure if it prematurely happened and the removeal of the cat has caused it, or what...
But Say... if I drive her 10 miles down the road (lake ave to walmart near circle drive in the springs); shut her down, go in walmart (or whatever place for ten minutes) and come out.. turn her back on she doesn't want to start... and sounds as if she's gonna flood (The Denver folks noticed it last night at Starbucks).... or, takes a few times to turn over before she has enough power/gas to keep at idle. However, if I let off the gas after the initial start up - she'll die. If i keep her idling around 3k rpm, let my foot off about 30 seconds later - she'll idle to 100 and stay put.... then a few seconds later, she'll go from 700rpm to 100rpm..
Would this also be a cause if .. we ever so happen let a larger gap on mistake from the exhaust manifold to where the straight pipe starts? That's where my final exhaust leak is, and will be fixed soon...
but this is alittle annoying and freaking me out I guess... Otherwise she runs *perfectly*.
13B n/a Street Port
Goopy performance
2005 Mazda 3
nothin' but stock love.
alex_n/a
Postby alex_n/a » Tue Mar 01, 2011 9:14
christi wrote:So, as some of you know, I replaced my cat on Sunday. She runs perfectly, loud and backfirey :D However, I've ran into a issue. I'm not sure if it prematurely happened and the removeal of the cat has caused it, or what...
sounds like your cold start is not functioning correctly. Does your 7 rev up to 3k during its first start of the day or after a few hours of not starting up?
Also since you removed your cat you may not be creating enough back pressure. on another note, did you wire open your 5th/6th ports now that the cat is removed and you might as well remove your emission equipment since you have no cat.
About your gas millage, I'm sure it was just heavy driving. or the loss of low end torque is now making you keep your rev's up making you waste more gas.
Disclaimer: It's late and most of that is what I have been told by other rx7 owners :mellow:
christi
Postby christi » Tue Mar 01, 2011 9:14
I'm not sure. It starts up just fine when it's cold, it's just after I drive for a while. I can drive for long distances and it turns on just fine. However if I drive just for a few minutes, turn her off, come back a few minutes later - she'll try to flood ... or what seems to be flooding.
When I showed Jimmy (GR-8) what she sounded like that Sunday night and turned her off... about a half an hour later when we were leaving for OC she didnt want to start again. HOWEVER, two hours later while in OC (Old Chicago) she powered and fired right up.
I did not wire open the butterfly ports... Are you suppose to after removing the cat? I was not aware of this.
My smog pump has not been working since Nov, 2010 when the bracket b roke after replacing my OMP - we just disabled it. She's ghetto "plugged" (seeing on page 1) at the moment until I can properly make a block-off plate.
13B n/a Street Port
Goopy performance
2005 Mazda 3
Postby iani1.1 » Tue Mar 01, 2011 9:14
sounds like leaky injectors to me, also the smog pump is useless on the s5 since the aux ports are electronic and go by rpm rather than vacuum pressure.
removing the cat shouldnt affect anything, unless you care about low end torque which the fc doesnt really have anyway lol
removing emissions will lower your city mpg quite noticeably since it wont recirculate the unburnt fumes from combustion. also it will run pretty damn rich. i removed mine cause i was gonna bridgeport later and wont be needing it. also youll get that cel back if you remove your emissions on an s5... i think.
Postby GR-8 » Tue Mar 01, 2011 9:14
Thread Jack. Why doesn't the 89-91 rx7 have a freaking OBD1 port? I found out online that the 88 does and it's under the dash. Do you really have to jumper the freaking wires and read the blinking CEL to decode what is wrong with the car?
I know the scanner will tell me where it is and what adapter to use to read the code but I didn't have the cig lighter adapter with me. The battery was out. I'm gonna plug it in to the wall when I get home. See what it says. I probably couldn't find the right adapter. It's kinda pissing me off.
christi
Yes. Thank you for reminding me. I still haven't found ANY information on how to read my freaking car's CEL! Someone please explain this!
Also, The reason why I replaced the cat with a straight pipe is because im gonig full exhaust system, but this shouldn't be effecting anything with starting up, but it started happening that night *after* everything was finished (exhaust system is not). The CEL was around before the smog pump broke....
13B n/a Street Port
Goopy performance
2005 Mazda 3
FCs dont have a obd port at all. actually most if not all pre 92 cars dont have em.
but this helps -scroll to look for it-
http://www.rx7city.com/ecucodes.htm#How_To_pull_ECU_CODES_for_your_1988_-1991_RX7
christi
Per that that link & what Mazda quoted me back in November '10 - They did specify I had CEL 10 (10 Intake air thermosensor (AFM) )
But I still want to get a secondary reading *just* to be sure.
Also... why did mazda make it to where my model does *not* have... a obd reader? that's just silly! (More profit for them, I guess)
13B n/a Street Port
Goopy performance
2005 Mazda 3
iani1.1 wrote:FCs dont have a obd port at all. actually most if not all pre 92 cars dont have em.
Very easy to do. The list of codes makes things easy. To bad I did not have a wire to jump/ground the connector.
