[color="SeaGreen"]So, I've been thinking a lot lately on how I'd like to modify my car. I have a few things I'd like to do, but I love input from you guys - if you have an idea of what I should do than what I'm wanting to do.....
This is pretty much my street-suspension-build...
In the future list:
*Front and rear upper strut tower & other chassis bracers (Generic-brand should be fine for the most part, right?)
*Front and rear swaybars (Suspension Techniques) - Front sway bar: 203$; rear: 193$; set: 375$
*Performance struts (Koni Sport Yellow or KYB AGX) - [from koni - http://www.raceinspired.com/p-16792-koni-sport-yellow-shocks-mazda-rx-7-1986-1992-rear.aspx 148$;
*Sport/lowering springs(Tanabe)
*Front camber/caster plates(Any suggestions?)
*Polyurethane suspension and chassis bushings(Energy Suspension)
*Complete coilover kit instead of the separate springs/struts/chamber(instead, unless that is too expensive?)
Updates:
What I've done so far:
*13B S4 N/A Mild street port
*Removal of 6-port butterfly valves
*E-Fan Conversion (SHO fan)
*RB Dual Header 3"
*Straight pipe to the Y-Pipe 2.5"
*Partial Pre-mix conversion.
*K&N Filter w/customer intake pipe.
*All Emissions have been removed
What needs to be done soon:
*Re-wire of the car
*Replace radiator - hopefully in a few months - going to be using Koyo is what I hear is best for these cars.
*Replace Y-Pipe with aftermarket exhausts - no idea on the mufflers yet.
*Need to get a EFI system - car runs STUPID rich - Any recommendations?
[/color]
My modification thread..
Just some things I'd like to note...
Well, when I suggested Tanabe for the sport-springs, I also did make note that careful research should be done into comparing various companies for both spring-rates and the amount of ride-height alteration that the springs do... So Tanabe is just for starters. I myself have the DF210 Tanabe springs on my STi - but that was because they just *happened* to have the closest-to-optimal spring-rates and drop for what I was after.
One reason also why I do suggest sport-springs over full-blown coilovers, is that most likely you'll end up with a gentler ride - seeing as most sport/lowering springs, while they do have increased spring-rates, tend to have progressive-rate springs. This is not necessarily what you want for a serious high-performance build, but sufficient for improved handling on a street-use vehicle.
When it comes to 'generic' or E-bay strut-braces and such, you still need to be careful to pick the right/best units, if they're even available for the car (I'll admit, I haven't checked, as of yet). While they may not be the absolute best on the market, by ANY means, they can achieve 60-80% of the goal that a much higher-priced name-brand unit does.
I had more I was going to say, but my train of thought got hiijacked by terrorists... I found the train, but the box-cars were empty. I'll post more later, when I remember.
2006 Subaru Impreza WRX STi "Sumaire"
World Rally Blue Pearl
415 bhp, 410 ft-lbs
...And yes, it can actually take corners now, too.
"Racing makes a heroine addiction look like a vague craving for something salty!"
you wont need lowering springs if you go with the coilover kit but your talking like an 800 dollar diff. but I would go coilovers if you have the moola and I have heard the poly bushings are kind of squeeky can anybody confirm im not sure just what I have heard looks like you have a pretty nice set up in mind
well i'll tell you my future plan maybe you'll like some
e-fan
godspeed radiator
manual steering rack (actually already have one)
performance brake pads
supra brake booster
hood strut
custom intake (currently working on)
header (dual exit) - test pipe - silencer - 2 n1 mufflers or racing beat for a true dual exhaust system
lsd
turbo tranny
gauges (to monitor not for looks lol)
some of these are not really mods just things you can do to your car
e-fan
godspeed radiator
supra brake booster
hood strut
lsd
turbo tranny
christi
[color="Green"]Oh yes. Totally doing the E-fan. That'll be installed when I get the test pipe done in a few weeks.
Hm... The header idea is not too bad; but I'm wondering if I should just do the test pipe and when I switch with my TII swap do the rest of the deader/silencer/mufflers.. (Racing beat is pretty good... I was thinking HKS, RB or CS.)
Godspeed? I.. . never heard of them ... Are they pretty good?
[/color]
[/color]
Coilovers also make it easier to make you handling go to complete shit when you dial them in wrong. I usually recommend to people to either get the best coilovers you can afford and do it right, or just get shocks and springs. Unless you're building a race car, then Motons and JRZ's are typically overkill, so stick with spring/shocks.
Also, aftermarket shocks such as Koni's tend to last much longer than most aftermarket coilovers, so they don't need rebuilding every 10,000 miles like most Teins do (let alone knock off EBay coilovers, inconsistent spring rates and incorrect valving abound). Coilovers also tend to be too stiff (the Japanese suspension tuning philosophy is one of "stiffer is better") and can induce snap oversteer in most rear-wheel drive vehicles and lead to a kidney punishing ride.
/rant, I recommend shocks and springs.
christi
Over looking the prices, I would guess getting shocks/springs will be a bit less expensive than doing the coilovers. ... It seems to me that Koni is my best bet out of reviews; I love koni anyhow. It looks to me so far that i've priced out (and still looking and reviewing more) that I'll likely spend 1000$ before everything's done... I'm hoping to atleast have some mods done before Deals Gap, but I'm not counting my self..
christi
BTW, if you didn't see it in the "chat"... here is what I'll be picking up on my vacation trip to TN to meet half-way with my parents .. 04/26-05/02
http://yfrog.com/gznzgcnj
13B n/a Street Port
Goopy performance
2005 Mazda 3
nothin' but stock love.
13B n/a Street Port
Goopy performance
2005 Mazda 3
christi wrote:Also: any idea for the best place to have my test pipe installed in the springs.?
If the test pipe is removing one or more catalytic converters, no shops will do it. They risk hefty fines for removing cats. Usually test pipes are super simple to install yourself. A couple bolts on either end is usually all it takes.
