possible smokey turbo fix speed6
04rx8
Postby 04rx8 » Fri Apr 01, 2011 9:14
So I recently did a highflow catted 3 in dp by Atp turbo with magnaflow catback had hella oil coming out of exhaust and other smoke coming out so I took off the magnaflows and now I'm straight piped it sounds very similar to a srt4 but it pulls way better and guess what no smoke no oil smell nothing so maybe great success accept for the srt sound?
Postby erod550 » Fri Apr 01, 2011 9:14
Making it sound like an SRT4 would be a good thing, not a bad thing. :P Best 4 cylinder exhaust I've owned. Almost rather hear one of those than an STi with exhaust... almost, hehe.
It's weird that the catback fixed the smoking. Catbacks don't much except change the sound on these cars. All the backpressure is in the downpipe. But glad it fixed it for you.
COTURBO
Junior Member
Postby COTURBO » Tue Jun 14, 2011 9:14
04rx8 wrote:So I recently did a highflow catted 3 in dp by Atp turbo with magnaflow catback had hella oil coming out of exhaust and other smoke coming out so I took off the magnaflows and now I'm straight piped it sounds very similar to a srt4 but it pulls way better and guess what no smoke no oil smell nothing so maybe great success accept for the srt sound?
that is probably not a good thing. Your cats were probably burning the excessive blowby that you still have.
You need to do a compression test and check your oil level.
04rx8
Postby 04rx8 » Fri Jul 15, 2011 9:14
Def mostly not a engine problem she runs like a champ, def prolly mostly the shitty Ko4 turbo that burns oil from day 1.....thats ok when I get back from afghanistan im going to go big or go home :)
Silver 06 speed6 mods: E85 mix 40/60, Atp highflow catted DP, Cobb Accessport, custom AP pro tune by Servion tuned at 22psi. Corksport FMIC with Ram Air intake, SURE Engine Mount, HKS 2 step colder plugs gaped .28, Forge v2 bpv, Straight piped exhaust 2.5 IN, light weight 17 in black wheels lowered on Tien lowering springs, slotted rotors, hawk pads all around. When I get back from afganistan built block, big turbo, clutch and supporting mods :)
dsm_luck
Postby dsm_luck » Fri Jul 15, 2011 9:14
Its the seals on the K04. A gt3071 or 3076 will fix that nicely.
Users browsing this forum: No registered users and 11 guests
