OK silly question I am sure but then again I never pretended to know all that much about cars. One of my tires has a wonderful bubble in the sidewall and needs to be replaced. My options are to buy the exact same tire for like $200 or take the 2 brand new tires of the same size off of my other car. The only thing is, they tires I would be taking off my Beetle and puting on my 8 are Z rated where as the preformance tires curently on the 8 are only R.
Here's my question, if I put the Z's on the 8, would it be better to have them on the rear axel or the front? I imagine the rear for the power traction would be nice but would they be at all beneficial up front for the cornering? Any input would be appreciated.
Z and R rated
I wouldn't think it would make a difference. Just put the ones with better thred in the back.
Probably rear. If the Z rated tires are softer, which the treadwear rating can be an indicator of (but it's not quite as black/white as that), then put those in the rear. Stickier tires on the rear keeps the rear tires behind you and keeps you from wrecking.
- Colombia28
