Turbine Tech Front Engine Mount: MAZDASPEED 6
Postby SpeedRacer » Thu Dec 25, 2008 9:14
Application: MAZDASPEED 6
Made out of 6061-T6 high yield strength (35,000 psi), this full TIG-welded aluminum construction is built to last. Assembled with urethane bushing for increased rigidity, this strong and sturdy mount will keep that powerful motor from traveling back and forth in the engine bay. It virtually eliminates wheel hops and keep your drive train away from those nasty shocks it produces.
How would an additional mount ease off the stress on the rear diff? To things, one is the drive shaft being slapped repeatedly by the engine moving back and forth under acceleration. At the back, your differential is being shacked like a baby seal in the shark's jaws. Second, your tires are not getting a permanent grip all the time, but rather bites on and off several times per second, thus inducing wheel hop. How serious this problem is may vary depending of your driving habits, tires compound, dirt on the ground, etc. This may or may not be noticeable but it does happen at various rates. When it happens, the shocks translate to the drive train by the CV joints, heavily stressing out the front differential mount. Keep the engine steady, keep that drive train safe!!
List price $299.00
For sale $200.00 but you need to meet up with me and help take it off.
