WTB Mazdaspeed3 OEM tire
Justin
Postby Justin » Mon May 18, 2009 9:14
Some debris tore up the sidewall on my driver's rear tire, need a replacement. Anyone have a stock MS3 tire (or two) for sale? Need some tread depth, but not much.
WINGSPD
Used Tires (available?)
Postby WINGSPD » Fri Aug 14, 2009 9:14
Justin, this may be too late or maybe good for one or both of us. I just ran a horseshoe nail through the sidewall of one of my OEM Bridgestones and am looking to either replace with a single used tire, or to replace all four, as it is at least half way worn. I was hoping to get longer wear than average out of my set, but this throws a wrench into my plans. If you haven't replaced yours, or if you still have your originals, I might be interested in buying one or selling mine to you (depending upon the conditions). Thanks, and good luck. Darby 8/15/09
Postby dommo_g » Sat Aug 15, 2009 9:14
I have a used set of OEM tires I can part with. I can get tread depths and pictures on Monday if you guys can wait that long.
