smoking tail lights
The How-To Forum
AxelaR8
Junior Member
smoking tail lights
Postby AxelaR8 » Sat Jan 01, 2011 9:14
On my mustang I used rvinyl's tint for the tail lights and it was easy and looked good. For my 2011 3, they don't make the tint because of the odd angles and surfaces of the tail lights so I've started researching spray tinting. Any thoughts?
Postby TheNewBlack » Sun Jan 02, 2011 9:14
Check for other threads on this.
Postby iani1.1 » Sun Jan 02, 2011 9:14
lamin x are always good. fiment is a tad bit short but hardly noticeable.
http://www.lamin-x.com/
Postby Number2 » Sun Jan 02, 2011 9:14
you could try this as well. I had these on my old scion tc, and looked awesome.
http://www.bluebatmobile.net
or
http://s2.photobucket.com/albums/y42/BlueBatmobile2005/Mazda%203%20Overlays/
Nevermind. I didn't see a 2011 mazda 3 shown. Maybe if you can contact him, he might have one done.
Postby RX-7 Chris » Mon Jan 03, 2011 9:14
Talk to Eric (OCD) on the forum, he could probably do it.
Postby tbot » Mon Jan 03, 2011 9:14
^^this...I KNOW he can do it, for a fact.
Postby Number2 » Mon Jan 03, 2011 9:14
See Eric (OCD) for sure. I prefer tinting to painting, because you can't undo paint. And if it doesn't come out right and he has to take it off, he won't charge you.
memphis
Postby memphis » Mon Jan 03, 2011 9:14
ya,, use Eric.. His prices are good and its always good to support the local shops rather than always buy from the internet..
AxelaR8
Junior Member
Postby AxelaR8 » Wed Jan 05, 2011 9:14
Thanks for the replies, I'll hit him up!
Hschlick84
Postby Hschlick84 » Fri Jan 07, 2011 9:14
Lamin-X is good stuff, highly recommended. Keep us posted!
dozer
Postby dozer » Tue Mar 15, 2011 9:14
Pep boys actually sells a spray on tint, The more the coats the heavier it gets. Out of the 13 cars I've owned I have used the spray on six of the cars. Looks good.
Mikedubs
Postby Mikedubs » Tue Mar 15, 2011 9:14
OCD did mine, but you are gonna have to twist his arm to do another MS3. Those tail lights are a bitch.
Postby Learjet45 » Tue Mar 15, 2011 9:14
This is fairly old, but I'm still going to post.
The lights on the new 3 look horrible to try to tint, but it can be done.
There's a good tutorial over on mazda6club that someone wrote up about tinting the mazda 6 tail lights using VHT NiteShades spray tint (and sanding and polishing to make it look good). I thought the turn out was very nice, and I've wanted to do this myself but haven't yet. Apparently you can remove the VHT NiteShades with some lacquer if you mess up also. I can get the link if you want.
Eclipse
Postby Eclipse » Wed Mar 16, 2011 9:14
Lacquer will DISSOLVE plastic... not sure that sounds like a good idea. Seems to me the only way to do that spray tint right is to not **** up the first time, otherwise a new set of taillights may be a purchase for you in the near future
Powerstroke 6.0
Return to “DIY”
Users browsing this forum: No registered users and 5 guests
