Postby chromal » Sat May 07, 2011 9:14
Here's what I've got for tire pressure. Unfortunately, I didn't keep any records on tire pressures until I had owned the car for about 11 weeks, as I didn't have a gauge worth trusting. Possible alignment-affecting issue on 2011-02-09...
2010-08-06, odo 14
[INDENT]purchase vehicle[/INDENT]
2010-09-27, odo 3810
[INDENT]Groove Mazda full circle inspection (theoretically resets PSIs to spec)[/INDENT]
2010-10-09, odo 4498
[INDENT]rotate rears to fronts[/INDENT]
2010-10-23, odo 4995
[INDENT]45'F ambient, FL: 30 PSI, FR: 31 PSI, RL: 30.75 PSI, RR: 30.5 PSI (buy tire pressure gauge with intent of monthly monitoring after TPMS trips on cold morning)[/INDENT]
2010-11-xx, odo xxx
[INDENT]Buy tire fill bit for air compressor. I'd like to think I reset to OEM spec, 32 PSI then, but if I did, I neglected to annotate it in car log[/INDENT]
2010-11-26, odo 6326
[INDENT]swap to winter wheels+tires (will omit winter wheel details)[/INDENT]
2011-02-08(ish), odo 9400(ish)[INDENT]Still on winters. Slow too much while entering driveway slight uphill grade from road, lose traction, slide backwards across narrow road into car-eating ditch around 10pm. Starts with just a corner on ditch lip, but all attempts to pull out just make things worse. Bottom out in snow. Temp drops below -8'F, heavy snow. Give up trying to free car with shovel. 18" fall on car overnight. [/INDENT]
2011-02-09
[INDENT]Pulled out by county plow with chain on rear right corner structural or suspension element. After pulled out, I slow and stop. They do not, there's a pretty hard impulse as chain jerks vehicle. Thanks, I guess. :/[/INDENT]
2011-04-01, odo 11008
[INDENT]replace winter wheels with OEM wheels + tires. Inflate all to 34 PSI (2 PSI over) @ 50'F figuring it's still basically winter/cold.[/INDENT]
2011-05-07, odo 12680
[INDENT]55'F ambient, FL 33.5 PSI, FR 34 PSI, RL 34.0 PSI, RR: 34.5 PSI. Reset all to 32.0 PSI.[/INDENT]
Sorry for somewhat spotty notes, definitely am making effort to be more diligent, here. So, I dunno. Given the above, I'm not sure if the tire pressures are cause for concern here or not. It was hard to keep tires consistantly at 32'F cold temp when we were seeing swings from 18'F-50'F, though at no point did they get so low that TPMS stayed lit after tire warmup. I overinflated by 2 PSI in April to forestall TPMS cold start trips, but was that a mistake? No clue on alignment, but I assume there's not much point in even getting a check on these tires, give they are not new.
I absolutely intend to get an alignment check at the very least when acquiring next set of tires. Any recommendations on where that gets done? Big box tire retailer? Groove mazda? ______?
