My new car!
Postby chickenwafer » Fri Mar 15, 2013 9:14
I'd say PlastiDip holds up to rocks as good, if not better, than a wrap. It's also considerably cheaper than a wrap. From what I've gathered, a typical wrap will run you $3-5k installed. You could Plastidip your entire car for under $600 bucks and do it yourself.
Plus a if wrap does get damaged, you need to peel the entire panel and replace. So depending on location, that could get really expensive. With plastidip, it works just like spray paint, so you can simply paint over the damaged area or peel the panel and reapply.
The plastidip on my wheels has held up great thus far, no chips or issues yet
Operator
Postby Operator » Sat Mar 16, 2013 9:14
Looking to hit the road next Sat. Something local, and only for about an hour or so. Clean your calendar, and make sure the car is gtg.
JL 1000/1 - JL 450/4
[/font]
Current:
Postby chickenwafer » Sat Mar 16, 2013 9:14
Operator wrote:Looking to hit the road next Sat. Something local, and only for about an hour or so. Clean your calendar, and make sure the car is gtg.
Car is ready to roll, but I work Saturdays :mad:
I should be available the Sunday if you wanted to go then?
Operator
Noooooooooooooooo!!!!!!!!!! I go back to the field Sunday!!!!!! I think we are destined to never take a cruise together!!! Give me your bosses number, I'll handle this!!
[/font]
Current:
Postby chickenwafer » Sun Mar 17, 2013 9:14
Hmmmm well could you do Thursday? I'm off then.
Operator
Postby Operator » Sun Mar 17, 2013 9:14
Probably, it'll probably be just us two.
[/font]
Current:
