Time for new summers: thoughts?
Tire and Wheel Discussion
Postby Colombia28 » Sat May 25, 2013 9:14
Saul_Good wrote:Was it the RE-11 or RE-11A?
RE-11. Not the "A"
Postby Colombia28 » Fri May 31, 2013 9:14
Please help me welcome my Speed back to the world of grip!
Regulator
Postby Regulator » Fri May 31, 2013 9:14
Awwww yeaaaaaa. Nice looking treads!
Hot off the press with some of the sticker still left behind :)
Postby Colombia28 » Sat Jun 01, 2013 9:14
It takes a little getting used to the insane level of grip! I have to remind myself that the winters are off and I can now drive. Makes me want to hit up HPR bad.
Saul_Good
Postby Saul_Good » Sat Jun 01, 2013 9:14
Colombia28 wrote:Makes me want to hit up HPR bad.
I like this
Saul you might be able to help me out with this too. I want to get a set of 17" wheels and tires for track use. I'm just not sure what size wheel (17x?) or what size tire for said wheels. Just knowing that standard 3 wheels fit the ms3 and using the old tire rack it says the OE recommendation is 205/50-17. Can I go wider than 205? Any recommendations?
Postby Shadowden » Sun Jun 02, 2013 9:14
I recall my stock mz3 wheels being 17x7. Lowered on eibachs, I don't think I was even close to rubbing. I'm pretty sure you could run some 225 on there. That may actually be what I had. I forget the aspect ratio.
Postby bellalyssa » Sun Jun 02, 2013 9:14
I ran 225s on my 3 with the Eibachs. Plenty 'o room.
Saul_Good
Postby Saul_Good » Sun Jun 02, 2013 9:14
Columbiana, Assuming your stock wheels are 17x7, 215/45/17 should be a good size that maximizes your 7in width.
If the offset is right, i think you can get a 17x8 or 17x8.5 wheel and squeeze 245/40/17 on. I'd triple check with the MS3 forums to be sure tho. If not, then 17x8 with 225/40/17.
Just be sure to get the proper offset.
Return to “Tires and Wheels”
