Not too much is new right now, have been procrastinating projects for warmer weather and melted snow, though in recent weeks there have been a few breaks in the weather. I took the Miata out for a few drives in the foothills and get to know it better. All said, I've put about 1000 miles on it since January, essentially most of that west of CO-470.
Finally seemed like it was time to do something about the gaping hole where the OEM audio headunit was. The previous owner had prioritized body work after buying it with a custom audio setup freshly removed. Fortunately, the factory harness points were intact. The previous owner generously included an OE audio harness connector, as well as what seems a really quite decent CD-MP3 Kenwood head unit.
Fortunately, the head unit harness wires had labels affixed and I had the factory service manual for the car side audio connectors. I set up the front L/R door speaker channels, ACC, and B+ connections by soldering and then insulating with head shrink tubing. There was a separate ground wire with the car's audio harness that I used a wire nut on.
Around this point, I discovered there was a fried voice coil in the driver door speaker, an Infinity Kappa 62.1i 6.5" 2-way full range driver. Doesn't seem easy to source an identical replacement for just the blown speaker. Both door speakers will be replaced with something else, not sure what, yet, beyond it will be decent but on a tight budget.
There's a short list of things I want to work on soon:
timing belt, water pump, coolant, front engine seals
possibly bent hood hinge
popup headlight linkage bushings
center brake light
cabin rear deck carpet
right rear rust
and stuff I hope to address before next winter:
engine rear seals
transmission seals
differential seals
air conditioner
hard top shell repair, hard top window
We'll see..
