overheating problem?
REd88GTU
Postby REd88GTU » Tue Sep 23, 2008 9:14
so ive been having a problem with the rx-7 recently. i cant tell that theres any performance issues (yet) but everytime i get out of the car after driving it, it seems to smell like its overheating a bit. its not overwhelming though and everytime i pop the hood to check up on it, theres no steam or smoke coming from anything. im beggining to wonder if its just normal (its an 88 and the car has 144k on it). but i baught the car a couple weeks ago and i dont remember it happening then. im going to do a coolant flush and an oil change and see if that does anything. does anyone have any experiance with this? is it something i should be worried about? any info would be greatly appreciated.
[color="Red"]88 Mazda Rx-7 GTU[/color] (SOLD)
94 Mazda Rx-7 Touring (Bolt-ons, catless turbo-back, PFC, Stance CO's, PF Supercars built and street ported,+99 Spec Twins)
[color="DarkRed"]94 Pontiac Firebird Formula[/color] (Bolt-ons, SOLD)
[color="DarkRed"]99 Nissan Pathfinder[/color] (VG33E, DD, in need of a supercharger)
RX-7drifter
Postby RX-7drifter » Tue Sep 23, 2008 9:14
check the thermasat i know mine had a problem with that
Low Impedance
Postby Low Impedance » Tue Sep 23, 2008 9:14
what is your temp gauge reading?
check the thermostat. USE ONLY the oem thermostat unless or drill a hole into the thermostat about 3/16 to 1/8 inch. (ie small ish)
WWW.RCCDIGIZINE.COM
REd88GTU
the temp gauge seems to be ok. it hasnt been too high. drill a hole in the thermostat, realy? would you mind explaining?
Low Impedance
teh factory thermostat has a thing. that have an odd ball name like Jiggler valve or something. just a hole in the thermostat that relieves pressure and i think may help the thermostat from getting stuck (which is bad)..
if you smell heat and your not over heating, i have another thought...
do you have any catalytic converters on your car?
WWW.RCCDIGIZINE.COM
Postby RX-7 Chris » Wed Sep 24, 2008 9:14
I can take a look at the car if you want. If you show up at the sonic this friday I can look at it then.
It couls also be a pin hole in the heater core but then you might have sone window foging. Atso could be a pin hole in the radiator.
If you buy a theristat from the dealer it will have that pin hole (the best way) or you could get one from the parts store and drill the hole. Mazdatrix.com sells the mazda one as well.
Low Impedance
Postby Low Impedance » Wed Sep 24, 2008 9:14
he would also be noticing a loss of coolant (over time) and some acutally temp gauge indication of over heating...
what does the gauge ACTUALLY sit at. be descriptive.
WWW.RCCDIGIZINE.COM
Before I did my motor and changed the radiator. I had a pin hole that didn't really spray, it just weeped. It wouls smell like coolent but I would never see a real drop. I maybe lost 2 table spoons over a month out of the overflow tank.
Low Impedance
im not sure if he is smelling hot coolant or hot metal
WWW.RCCDIGIZINE.COM
that is why I really want to see it.
Low Impedance
if he still has cats, i wonder what shade of red they might be glowing....
WWW.RCCDIGIZINE.COM
REd88GTU
Postby REd88GTU » Wed Sep 24, 2008 9:14
Low Impedance wrote:teh factory thermostat has a thing. that have an odd ball name like Jiggler valve or something. just a hole in the thermostat that relieves pressure and i think may help the thermostat from getting stuck (which is bad)..
the owner before me installed a high flow cat. could that be it?
rx-7 chris: yea ill be at the sonic on friday and ill show it to you.
Low Impedance
odds are the high flow cat is kaput. rotaries destroy exhaust components and aftermarket cats generally have no chance.
WWW.RCCDIGIZINE.COM
REd88GTU
well shit its not like i need one anyway! haha! taking it off would prolly make the smell worse. but if i know its just that then i dont realy care. i just want to make sure theres nothing mechanicaly wrong with the car.
goldrocket
Postby goldrocket » Wed Sep 24, 2008 9:14
So let us know exactly where on the guage your needle is pointing when you shut the car off. Also let us know if the smell is inside the car or out. Chris hit the topic I was thinking, heater core. And yes, the hole in the t-stat works. My car is a ported 13B and I was having cooling issues. not just smelling like it was hot, but trying to overheat. I drilled 3 3/16 holes in it and added a coolant additive, not more cooling issues. Just for reference I have a new water pump, radiator and radiator cap. ONce all that was fixed my heater hose sprung a leak, fixed that too. Now she stays cool under the supervision of two 10 inch electric fans as well. And don't worry, if you remove the cat it won't make it worse....mine hasn't had one since long before I bought it. It seems Racing beat knows how to make a rotary exhaust that doesn't fall apart.
Al says
Users browsing this forum: Google [Bot] and 44 guests
