Car Pulls To The Right
Tire and Wheel Discussion
Postby Huzer21 » Thu Oct 04, 2007 9:14
<div class='quotetop'>QUOTE (6i_guy @ Oct 4 2007, 08:44 AM) [url=index.php?act=findpost&pid=3338]<{POST_SNAPBACK}>[/url]</div>
I don't think you are lonely anymore...there are more friends....you say your car always pulled to the right? I don't want to upgrade th 18" to see if that
is the issue. I am hoping it is just air pressure...but that was supposed to be the first thing they checked....?
we are entertaining the idea of trying different tires to see if there is a difference..[/b]
I think my 6 had other issues, which is what prompted my trade in. That would be weird, but not unheard of, if they didn't verify air pressure. I think Lee had a good idea, swapping sides and seeing if the problem follows the tire. If all else fails, just do what they do in that old Discount Tire ad, go throw a tire through their window.
cprtrainer
Postby cprtrainer » Thu Oct 04, 2007 9:14
Rotate the left side too- it could be a "radial push" versus a right side pull... Happened to me more than once on new treads...
Postby tsx_guy » Thu Oct 04, 2007 9:14
<div class='quotetop'>QUOTE (cprtrainer @ Oct 4 2007, 09:09 AM) [url=index.php?act=findpost&pid=3341]<{POST_SNAPBACK}>[/url]</div>
Rotate the left side too- it could be a "radial push" versus a right side pull... Happened to me more than once on new treads...[/b]
both sides have been rotated.... still happens...#@$#@$@#$
cprtrainer
<div class='quotetop'>QUOTE (6i_guy @ Oct 4 2007, 10:51 AM) [url=index.php?act=findpost&pid=3352]<{POST_SNAPBACK}>[/url]</div>
both sides have been rotated.... still happens...#@$#@$@#$[/b]
May need to try a diff tire- sometimes they just are not happily "married". Had that issue on an Elantra with BFG's- switched to Kumho's and never had a problem. I see many 6's running around on Yoko YK520's- might be worth a try!
<div class='quotetop'>QUOTE (cprtrainer @ Oct 4 2007, 03:38 PM) [url=index.php?act=findpost&pid=3417]<{POST_SNAPBACK}>[/url]</div>
May need to try a diff tire- sometimes they just are not happily "married". Had that issue on an Elantra with BFG's- switched to Kumho's and never had a problem. I see many 6's running around on Yoko YK520's- might be worth a try![/b]
I will keep that in mind...waiting to hear back from DT as they are replacing 2 of my rims as well....another story....
turbo99jetta
Postby turbo99jetta » Thu Oct 04, 2007 9:14
from what i know.. its common with mazda 6's to pull slightly to the right... some people notice it.. some don't.... all mazda's for that fact pull a little... 6's just a lil more from the factory...
<div class='quotetop'>QUOTE (Freezing Cx7 @ Oct 4 2007, 03:45 PM) [url=index.php?act=findpost&pid=3422]<{POST_SNAPBACK}>[/url]</div>
from what i know.. its common with mazda 6's to pull slightly to the right... some people notice it.. some don't.... all mazda's for that fact pull a little... 6's just a lil more from the factory...[/b]
yeah I heard that about mazdas as a whole....don't recall this doing it with the original tires tho....
<div class='quotetop'>QUOTE (6i_guy @ Oct 4 2007, 03:47 PM) [url=index.php?act=findpost&pid=3423]<{POST_SNAPBACK}>[/url]</div>
yeah I heard that about mazdas as a whole....don't recall this doing it with the original tires tho....[/b]
Maybe the new tires just exaggerated the effect? Who knows...at least it sounds like DT is working with you a little bit.
<div class='quotetop'>QUOTE (Huzer21 @ Oct 4 2007, 03:51 PM) [url=index.php?act=findpost&pid=3425]<{POST_SNAPBACK}>[/url]</div>
Maybe the new tires just exaggerated the effect? Who knows...at least it sounds like DT is working with you a little bit.[/b]
i'm bitch'n a bit....squeaky wheel....I had thought the same thing about the new tires exaggerating the pull....
my main concern is to make sure I am getting even wear from the start. I would like these to last for at
least a little while...
Postby SpeedRacer » Thu Oct 04, 2007 9:14
Guido stop taking rights only and it'll stop pullin that way sheesh... Take a left for once Zoolander.
<div class='quotetop'>QUOTE (SpeedRacer @ Oct 4 2007, 05:22 PM) [url=index.php?act=findpost&pid=3453]<{POST_SNAPBACK}>[/url]</div>
Guido stop taking rights only and it'll stop pullin that way sheesh... Take a left for once Zoolander.[/b]
I can't turn left....
Just do it man! I know you can!
Postby tsx_guy » Mon Oct 08, 2007 9:14
haven't checked this in a bit...have driven the car for a few hundred miles since then...this might have worked itself out....maybe....
Postby SpeedRacer » Mon Oct 08, 2007 9:14
I think you finally learned how to turn left welcome to the light young one.
<div class='quotetop'>QUOTE (SpeedRacer @ Oct 8 2007, 02:58 PM) [url=index.php?act=findpost&pid=4122]<{POST_SNAPBACK}>[/url]</div>
I think you finally learned how to turn left welcome to the light young one.[/b]
ahh the student has become the master...
Return to “Tires and Wheels”
