OCD wrote:I would love to see you do this with the stock k04 turbo on the speeds.. Lets see how inefficient 18psi on the stocker REALLY is..
I searched for the K04 compressor maps and there are a lot of variations out there, and most are measured in metrics I am not familiar with for the flow rate of the compressor.
I was able to find one, hopefully this is the same irritation the MS3/MS6 utilize:
OK, we already know from my cheat sheet at 18psi you have a PR of 2.45 in our altitude.
So, airflow demands on an MS3/6 at 2.45PR:
(2.3L)(6000rpm)(95%VE)(2.45PR)/5660=567cfm
(567cfm)(0.069)=39lbs/min
But wait, out compressor map is in grams per second. OK, yet another conversion:
(39lbs/min)(7.56)=296 grams/sec
Plotted!
Assuming this is the correct map (there are a lot of variations of K04"s out there) we can clearly see 18psi on an MS3/6 isn't even in NEAR the map on a this particular K04! An MS6 would be a little closer due to drivetrain looses but still wayyyyy off the map. The airflow STOPS at 240grams/sec and we need 296! Not even close. Compressor is a restriction at this point and pushing out super-heated air.
