Car Electrical Issue...
christi
I replaced the leading coil. I bought it from Don. If it's bad, then I'd like a refund.
People from the RX-7 group on facebook that I'm talking to (some of you know them, like Joe Noble), stated that it could be a Trailing coil. Until soemone actually *looks* at it to diagnose it, I don't know what else to do.
I cannot time anything as i do NOT have a timing light.
The guy who has my car, does not want me to time anything because it's not "running right" but I am trying to tell him that we need to time it. So I DONT know what to do, but I'm storing my car at my house probably this week/weekend. Which is why I realllly want someone to come look at it. I'm not smart in this area, and I'm sorry, I won't learn fast enough....
13B n/a Street Port
Goopy performance
2005 Mazda 3
nothin' but stock love.
13B n/a Street Port
Goopy performance
2005 Mazda 3
I know you said you were getting spark before the tach stopped working, but are you STILL getting spark when the rpm is NOT working, this may be your problem. it's worth a try.
alex_n/a wrote:is someone high?
im wondering that too. im pretty ****ed up on some jack and coke myself at the moment LOL
christi wrote:I replaced the leading coil. I bought it from Don. If it's bad, then I'd like a refund.
hm, i have a trailing coil you can have. its kinda apart but it works. whoever is working on your car is retarded. every car should be timed before diagnosis in other words it needs to be set at the stock or near stock specs to actually do diag. cant start where someone else left off.
oh yea do you have all the emssions removed and omp deleted?
christi
Well, he said that beacuse it's not running right, we should not time it. He's not a bad person, he just does not *know* rotaries....
Either way, I have no idea how to time it, and I certainly don't have a timing light ...
Apart? Haha, how does that work?
She idles, but she doesn't. So we did get her to idle for the most part, but the other half she just wouldn't idle, esp while she was driven.
As far as I know i'm still getting spark.
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
when it doesn't idle. does the rpm drop slowly until it chokes and dies. or is it a quick death? any vibrations?
Honestly, the issues you are having do not have much to with the car being a rotary, ALL cars MUST be timed to run properly, period. Yes, I know that timing a rotary can be a little challenging, but its not that difficult.
The leading coil I sold you worked perfectly fine literally a week before, so I doubt in a serious way it has anything to do with the coils and everything to do with the attempts at diagnosis.
Things that cause erratic idling in rotaries-
vac leaks/MAF issues
timing
bad grounds
bad plugs
bad wires
loose grounds
plug wires to wrong plugs
CAS issues
Bad ECU wiring, loose pins, etc.
Poor grounds
improperly adjusted idle
halfway or poorly done emissions delete
bad sensors (check ECU for CEL/code)
Also, please remember that a street-ported S5 REALLY needs to at least have an SAFC on it to lean it out since the S5 runs horribly rich.
timing
bad grounds
bad plugs
bad wires
loose grounds
CAS issues
Poor grounds
hm, an safc will only do a 20% correction (at the most?). meaning it can lean it out but not much. it may help? it might not. depending on how large of a street port. worse comes to worse go rtek which is a standalone compared to a safc which is a piggyback. with that said it may fix everything from idle to tuning it for a street port. that and its cheaper or about the same as getting an safc.
also the reason i asked if you have any emissions and the omp deleted is that any emissions removed or even simply unplugging the omp, WILL cause the car to go into limp mode since it is series 5 electronics were dealing with. which you can only really go 3k-3.5k at most.
i might be available this weekend to see whats going on. seems to be something simple but we'll see.
IIRC SAFC can do a lot more than 20% correction, along the lines of 50%, but its not really accurate anywhere near that IMHO, although opinions and experiences vary. If more than a 20% correction is needed on a stock fuel system then there is a serious issue. However it was designed to do EXACTLY what is going on here- fine tune a stock engine with some bolt-ons ie header, exhaust, etc. back into tune. Rob at Pineapple and I were talking about it and using an SAFC was actually his recommendation, I hate the things. His experience is that using an SAFC to dial back in a street-port with RB header and emissions delete nets around 180whp even with a cat. Christi's engine should net around 140-ish whp since it unfortunately still has the exhaust baffles in place.
Not a fan of the Rteks anymore, seems like a fair number of people have issues with them these days and not something I would want to use for a daily driver. Used SAFC's can be picked up for $100 or so with ease.Not saying an RTEK is junk, just not what really fits.
Did not do any of the emissions delete on this car, BUT (and I could be wrong) my understanding was that the emissions was deleted and done correctly. This is obviously something that needs to be checked, and by someone who understands the differences between S4 and S5, because as I have said, a halfway or improperly done emissions delete will really screw with the S5 ECU.
thats the reason why i consider getting an rtek. if emissions or whatever has been removed than a simple standalone will help even with a base map. as far as leaning it out not only she will need an rtek or safc you also need a wideband with a gauge to get a more accurate reading on what its at. a narrow band gauge might work but might be off but with the street port and it being an s5 will be getting a 1.5:1 or higher but i could be wrong... just throwing out the proper way to do it.
christi
And I'd like to do the proper way. But honestly I'm stupid with the standalones but I'm sure ill get to know how to use it. Of course after I et the car running right.
Ian, as it stands I am still off Friday and Sunday my usual
Shift. I am trying to get saturday off and work Friday. If I can't what's a good day for you ?
Sent from my iphone
Sent from my iphone
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
christi
Also, where is the temp sensor wire at? When we had the car running foe about 20 mins the gauge wouldn't move off cold. Or should I just get a aftermarket temp gauge?
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
The temp sensor that works the guage is below the oil filter right next to the oil pressure sensor.
Users browsing this forum: No registered users and 101 guests
