Volvo Fun, my '01 V70
tsx_guy wrote:i was looking at parts for my honda. I can get a chip/header and gain a few ponies, but it's all north of 5k rpm's where I rarely go. ugh...
good work sir!
According to my extensive research, that is where honda owns. VTEC!
Really why so shy of the 5 k?
Good job miT. Butt dyno report anxiously anticipated.
Now that I have more than 2 minutes to update...the wagon definitely has a very minor snarl when you get on it. Compared to a stock Volvo, that is. Compared to any other car, I doubt anyone would notice any difference. But the guy's welds that chopped out the center resonator are rather pretty. Wasn't expecting pretty welds on my exhaust, haha.
The only snafu was the catch 22 from Volvo. 2001s had their own special O2 Sensor connector. My R DP came from an 04. The 04 DP relocates the sensor back about 5 inches. Thus, I had to get a new O2 sensor and splice it in. Grr. If not for the connector mismatch, I could've just bought an '04 sensor and swapped it out with no splicing needed.
Finally swapped out the busted power steering reservoir today. Quick, easy job. replaced the low pressure hose as well. The old reservoir was in pretty bad shape, the cap gasket was shot, and the reservoir was bulging at the seams, unfortunately a common issue. All that's left on the R/R side of things (at the moment) is the heater core.
Snagged a 16T turbo for the car. Untortunately, the coolant/oil lines don't match the current configuration as the turbo was from a '99. Thankfully, they have a couple of correct 16t turbos in stock that I can swap it for, they just messed up at the parts counter and I didn't even check until I got home. I could use the CHRA out of the 13G and swap over the 16t wheel, as that would work fine, too.
Picked up the correct 16T yesterday. Cleaned it up a little after taking the picture below. Should wake the car up a little bit. I'll simply be separating the hot/cold sides as the exhaust housings are the same. This way, I won't have to remove the exhaust housing, which means I won't have to unbolt the downpipe and unbolt from the manifold as well. Wee!
Users browsing this forum: No registered users and 149 guests
