The S2000
- SecondGenPAt
Windex does work for this kind of thing.
Spent some more time with my stock wheels today. I got another wheel painted and the other two rough sanded with 150 grit. I don't really want to mess with wetsanding them, so I think I am going to try just polishing them first with cut, then swirl. Probably won't do much.
I also spent some time prepping the tubing that will eventually become my strut tower brace. Basically sanding all of the rust off of them. Also took a file to the seam of the cross bar to make it all disappear.
- AuroraAxela
Those look good. You were right about the silver centercaps. They work well with that setup!
Sweet! So were those the ones you painted? For some reason I thought you were getting them in blue... But I'm a teensy bit durnk at the moment...
Either way, coo!
Either way, coo!
looks good.
It's hard to tell in the pic. did you do the blue lip?
Looks sharp!
