Postby RX-7 Chris » Thu Jun 21, 2012 9:14
those parts are new. It's yellow zinc plating, you can't really fake that. I would paint the parts only because they won't stay that nice. If you want to keep that look you could always get raw steel look paint.
Postby chickenwafer » Thu Jun 21, 2012 9:14
Nice. Are those resurfaced and nitrated? I believe the gold is a zinc plating to prevent rust.
chickenwafer wrote:Nice. Are those resurfaced and nitrated? I believe the gold is a zinc plating to prevent rust.
that's exactly what the gold zinc is for. it is a sacrificial coating
http://www.isf.bz/Articles/Article7.htm
Postby speedjunkie » Thu Jun 21, 2012 9:14
Good to know lol.
Yeah I guess I'll paint them. I think I'm gonna start pulling the engine tomorrow. Maybe I'll paint them on Saturday.
And I'd like to thank you both for posting. I was starting to feel lonely. LOL
Postby VRx8 » Thu Jun 21, 2012 9:14
Eric are you building this weekend or next one? Im down to help out. I have to take my brother in law to Denver airport on saturday morning, I should be back a little before noon.
I forgot to answer this before. Yes they are. Last engine I built I only had them resurfaced and there was a lot of damage from the corner seals, looks like the rotors slapped the irons. This time I wanted them re-hardened.
VRx8 wrote:Eric are you building this weekend or next one? Im down to help out. I have to take my brother in law to Denver airport on saturday morning, I should be back a little before noon.
I'm planning on doing it this weekend, maybe even start pulling the engine tomorrow night. But I may not actually get to build it this weekend. Depends on the condition of the housings, seals, etc...whatever I want to reuse.
I'm sure I won't be able to have it running again before next week because I just ordered some plugs today to plug the coolant nipple (or lack thereof) when I cut it off.
Postby speedjunkie » Fri Jun 22, 2012 9:14
Thinking about doing solid corner seals again. Unfortunately this would set me back to finish the engine until next week sometime, but it's already looking that way anyway since I plan to get my 2-cycle tank powdercoated.
Anyway, I ran solid corner seals on the engine I built and I was happy with them. If I knew where they were and if they were in good shape I'd just reuse them, but if I remember correctly a couple of them were pretty worn down.
So, thoughts?
Postby VRx8 » Fri Jun 22, 2012 9:14
I say new solid ones sence your are using new plates. Old ones may not seal very well on the new plates.
Well other than the new irons, possibly new housings (depending on the condition of the current ones), new apex seals, and new oil control rings and springs, everything else will be reused. All the side seals and springs, corner seal springs and possibly corner seals, even the apex seal springs, will all be what's currently in there. This engine only has a few thousand miles on it, if that. I don't figure the corner seals would be bad already and I didn't think the housings would be bad already but looking through the exhaust ports I'm not so sure of that. I want to break it open and see what they look like all around. I may be picking up a pair of good used housings for $600, or $650 not sure which haha.
Alright nevermind, after doing some research I decided to stick with stock corner seals lol. I've thought about getting each end play spacer so if end play is off I won't have to wait for those either lol.
Postby chickenwafer » Fri Jun 22, 2012 9:14
Why stick with OEM corner seals? I think the solid seals are better but the OEM ones do make sliding the apex seal in place easier lol.
I was doing some reading and a lot of people were saying the solid ones wore down a lot faster. I had solid ones before and a couple of them had worn down if I remember correctly. That and other talk about the rubber plug helping against resonance from vibration and a lot of people were saying their solid seals cracked but the stock ones didn't. I would have thought otherwise.
The only downside to stock that I heard of was that the rubber plug didn't last long. But when I broke down my original engine last year I only had one plug missing. I thought about trying to get Viton ones but I haven't found any yet.
All that added to the fact that it's one less thing I'd have to wait on lol.
And in other news...after a discussion tonight about thermoswitches, I learned that FC thermoswitches come on around 207F and shut off around 194F, which is exactly what mine is doing. So I guess there is nothing wrong with my system lol.
Postby chickenwafer » Sat Jun 23, 2012 9:14
Right on the thermoswitch temperature range. But the fans can also be triggered by either the ECU, electrical load, or air conditioning. Your fans won't come on when the pfc tells them to, so my guess is there is something wrong is the relay for the ECU to turn the fans on. But all other systems are working for you.
