Foglights..
Postby SpeedRacer » Fri Apr 04, 2008 9:14
Heyo so I copied Jack and just removed my foglights for two reasons.. one um they were both broken from rocks lol and two for more air.
Just wanted to let you know what I found out :)
I watched my Intake air temperature alot while I had my cobb SRI on and it was always 15-20 degrees warmer than the ambient air sensor which is right behind the mesh grill on the bumper. With the foglights out I've been ranging from 5-12 degree's warmer than outside air which is a nice increase in cool air. the 8-12 is just while cruise control is on and your not actively sucking in air with some force. Just thought I'd share
K this is how they look and I have some toys inside there now... Total of 4.
Left fog light..
Right fog light..
Co626
Postby Co626 » Fri Apr 04, 2008 9:14
why didnt you build tunnels to you intake and brakes???? cheap ass jk
MS3_Mafia
Postby MS3_Mafia » Fri Apr 04, 2008 9:14
Damn I'm good!! Lol Another thing you could remove Josh... the rubber seal along the top of your hood. It releases alot of warm air from the engine while driving and at a standstill. Try it, you could easily put it back on too.
2007 Mazdaspeed3 Sport</span>
-Mazdaspeed Short Ram Intake
-HKS SSQV Bov
-Tein S-Tech Springs
S4poor
Postby S4poor » Fri Apr 04, 2008 9:14
<div class='quotetop'>QUOTE (MS3_Mafia @ Apr 4 2008, 12:18 PM) [url=index.php?act=findpost&pid=38301]<{POST_SNAPBACK}>[/url]</div>
Damn I'm good!! Lol Another thing you could remove Josh... the rubber seal along the top of your hood. It releases alot of warm air from the engine while driving and at a standstill. Try it, you could easily put it back on too.[/b]
^^^ I agree, plus the pad on the interior of the hood. That's there to reduce noise, and to prevent boiling the paint on the hood. Sorry, but can't see the hood ever getting hot enough for that to happen.
MS3_Mafia
Looks much better without the Fogs I think, especially with your Lip. :)
-HKS SSQV Bov
Postby Colombia28 » Fri Apr 04, 2008 9:14
<div class='quotetop'>QUOTE (RMSpeed6 @ Apr 4 2008, 12:44 PM) [url=index.php?act=findpost&pid=38308]<{POST_SNAPBACK}>[/url]</div>
^^^ I agree, plus the pad on the interior of the hood. That's there to reduce noise, and to prevent boiling the paint on the hood. Sorry, but can't see the hood ever getting hot enough for that to happen.[/b]
If your talking about the pad that is held with little black plastic tabs, then i personally suggest leaving it. From what i have read/been told, it is not to keep the paint from boiling (which i agree would never happen), but it is a fire suppression piece. If the engine bay was to catch fire, the little plastic tabs would melt off and the pad would drop onto the bay, thus creating a blanket smothering the flames and preventing a lot of oxygen from reaching the fire. Another reason why you should never open the hood of a car is the engine bay is on fire (don't feed the flames!) Unless of course you have the proper fire extinguisher to put out the fire...
Josh from what you saw with the bumper off, is there any way to duct air directly to the SRI?
bobopud
Postby bobopud » Fri Apr 04, 2008 9:14
Was the ambient air temp the same between you diagnostic runs? Different ambient air temp would lead to different intake air temp. The relationship between the two regardless of CAI or SRI is not a straight line curve and does differ as a function of the ambient air temperature.
I'm not saying that your results aren't accurate, just trying to get some more info as to whether or not it is the increased air flow from removing the fog lights.
It was roughly the same temps I've been watching it at different levels from 30-40 degree's - 50-69 degree's and noting the differences and am comparing it to what I see now.
Postby tsx_guy » Fri Apr 04, 2008 9:14
redirect the air to your brakes cheap ass... also any thoughts to removing the fog light housing as well?
MS3_Mafia
Postby MS3_Mafia » Sat Apr 05, 2008 9:14
^Fog Light housing... What you talking 'bout Willis??
-HKS SSQV Bov
Postby GR-8 » Sat Apr 05, 2008 9:14
Forgive Guido. His sign says 'No work. Wife and 6 kids to support' LOL He doesn't realize that it's molded in.
Edit: I think that you should paint it Matt black. I think Jack would agree.
Postby tsx_guy » Sat Apr 05, 2008 9:14
<div class='quotetop'>QUOTE (Greek8 @ Apr 5 2008, 06:56 AM) [url=index.php?act=findpost&pid=38439]<{POST_SNAPBACK}>[/url]</div>
Edit: I think that you should paint it Matt black. I think Jack would agree.[/b]
i understand they are moulded, but they kinda look empty sans foglights...if the goal is to get air up in there, remove the housing too, custom work...you
are good at that josh, then rerout the air via custom air dams... nevermind...
Postby Colombia28 » Sat Apr 05, 2008 9:14
<div class='quotetop'>QUOTE (Colombia28 @ Apr 4 2008, 01:19 PM) [url=index.php?act=findpost&pid=38325]<{POST_SNAPBACK}>[/url]</div>
Josh from what you saw with the bumper off, is there any way to duct air directly to the SRI?[/b]
Answer t3h question.
Yes I'm sure you could.
<div class='quotetop'>QUOTE (6i_guy @ Apr 5 2008, 06:40 PM) [url=index.php?act=findpost&pid=38527]<{POST_SNAPBACK}>[/url]</div>
are good at that josh, then rerout the air via custom air dams... nevermind...[/b]
in retrospect there is no clean way to remove the housings...and knowing you , you would f* it up.... big time making it look like poo...as usual
Postby SpeedRacer » Sat Apr 05, 2008 9:14
gee thanks Guido your motivating almost
