My Junk from Ohio
Low Impedance
Postby Low Impedance » Tue Aug 26, 2008 9:14
My turbo II and the 82 GS (eventually) while be coming out with me. My fiancee's vert will be making the trek with the Turbo II in October. Had lots of other non Mazda cars, but i wont bother to post that horde.
WWW.RCCDIGIZINE.COM
Postby Huzer21 » Tue Aug 26, 2008 9:14
Those both look nice. I wish I had a garage like that (or one at all! Haha)... with those high ceilings, the first thing I thought of was having a lift.
goldrocket
Postby goldrocket » Tue Aug 26, 2008 9:14
It' great to see even more ortaries coming!!! Especially another 1st gen!!!!
Al says
Low Impedance
Postby Low Impedance » Fri Sep 05, 2008 9:14
UPDATED PICTURES!!!!!!!!
OKay so last night was productive to say the least AND i still had time to go cruisn' with some local folks.
The water pump problem has been addressed. Went back to an FB housing. The belt is on, alt is set etc. No clutch fan since i have one belt. So i am going to commender a e-fan on a junk yard visit.
The batt. cables are all hooked up. Used an old FC brake line for the clutch cable. Bleed that.
Only problems are once i got the batt. installed and went to crank it, the start just clicks alot and doesn't do anything. I think i saved the bad starter i did on my friends Rx7 and for some stupid reason, it ended up in my car....
So this weekend i am going to plumb the FPR, deal with the starter, maybe finish the exhaust. And hope to see it start!!
WWW.RCCDIGIZINE.COM
Postby AIM WO4 » Fri Sep 05, 2008 9:14
You can fix the starter. It's probably the solenoid part on top of the starter. You can just turn the contact nuts around on some of them. They get worn down from the "plunging" action that occurs.
I just did this on my brother-in-law's 4Runner in the winter. Brrrr.
Got pics of the starter? LEFT = Bad, RIGHT = Good
Low Impedance
ill have to look. fortunately, the car has easy starter access.
WWW.RCCDIGIZINE.COM
