CP-E Nano Like new Used for 2 days
cyberspeed3
Postby cyberspeed3 » Mon Aug 10, 2009 9:14
SOLD! Thank you
Postby Colombia28 » Mon Aug 10, 2009 9:14
Good deal for essentially a new part.
wyosaint
Postby wyosaint » Mon Aug 10, 2009 9:14
does this marry up with the CPE Turbo inlet pipe?
cyberspeed3
wyosaint wrote:does this marry up with the CPE Turbo inlet pipe?
Yes, I called Street Unit for you and they said YES. You should come pick it up from me! :)
They also told me at Street Unit that he is Sold out of the Nano's until early September.
So get this one while its HOT!
wyosaint
I may have to, this one I got from Cobb rubs against my IC pipe
cyberspeed3
wyosaint wrote:I may have to, this one I got from Cobb rubs against my IC pipe
I have a stock setup and it did not rub on anything. As far as I know, I have never heard anybody talking about the Nano rubbing on anything.
UPS Ground from Denver to Cheyenne is only one day. Ship tomorrow, you have it Wednesday.
Let me know.
deepSpeedMS3
Postby deepSpeedMS3 » Mon Aug 10, 2009 9:14
i have this piece....nice piece that is....i love it....can i ask y your selling it?
B) deepSpeed MS3 B)
Eclipse
Postby Eclipse » Mon Aug 10, 2009 9:14
Mel, the ms3 nano will NOT fit the ms6. Cp-e is still in production mode of the ms6 model, it is quite different. The only way it will work is if you dont use the bracket (which will rub worse than your Cobb, and it will sit there like a limp noodle), or fab up a bracket to make it work. If Im not mistaken, you have the Cp-e fmic too, it def will not work with that. The elbow off the TIP is shorter on the speed 3
wyosaint
Does anything work with the turbo inlet pipe and CPE fmic?? crap
sorry I'm gonna pass.
OCD wrote:Mel, the ms3 nano will NOT fit the ms6. Cp-e is still in production mode of the ms6 model, it is quite different. The only way it will work is if you dont use the bracket (which will rub worse than your Cobb, and it will sit there like a limp noodle), or fab up a bracket to make it work. If Im not mistaken, you have the Cp-e fmic too, it def will not work with that. The elbow off the TIP is shorter on the speed 3
Eclipse
wyosaint wrote:Does anything work with the turbo inlet pipe and CPE fmic?? crap
haha, ya.. actually, If you got the downstep coupler with your TIP, most intakes designed for the speed6 should work, however, if you got the straight 3" coupler, (which Im assuming you did, because you have the Cobb) you will either need to keep the Cobb, or wait for the Nano. Jordan says it should be ready in the next 2 weeks.
I have the stepdown piece sitting in my bucket of parts if you want it, I have no use for it.. the negatives to it is (like stock) it goes from 3", down to 2.5", and then back to 3", seems like that would be a restriction. But, you can use almost any intake.
You could also do what I did, order a 3" 45 degree silicone tube, use your Cobb maf, and make a custom intake
Powerstroke 6.0
cyberspeed3
Its okay. I didn't know you had a 6. Street Unit assumed I was talking about a 3.
cyberspeed3
Postby cyberspeed3 » Mon Aug 17, 2009 9:14
Bumped for new lower price! C'mon guys this is a ridiculous price!
cyberspeed3
Postby cyberspeed3 » Sat Aug 22, 2009 9:14
SOLD Thank you
Users browsing this forum: No registered users and 106 guests
