New Alternator??
rush24
New Alternator??
Postby rush24 » Fri Dec 04, 2009 9:14
I'm in the process of setting up my new system for my CX-7...and I'm curious about additional upgrades that may be needed....I already plan on an Optima battery...but I'm not sure if I'll need to upgrade my alternator also....
The sub is a 1200w 13" DVC 2ohm....the amp is 1200w at 1ohm...the amp is
1ohm stable...
Thanks for the help...
Brian
2007 Black CX7
Apexcone Raptor 6000k HID...
3" DP back Exhaust System
SURE Motor Mount...
[/color]
LaginWagon
Postby LaginWagon » Fri Dec 04, 2009 9:14
What can your alternator produce? Amperage. What kind of amp, 1200w rms or peak?
Eclipse
Postby Eclipse » Fri Dec 04, 2009 9:14
At the VERY least, you need a capacitor... Ive ran 4000w on one battery and one alternator with no problems, so I wouldnt think you would need a second battery, have you looked into higher rated alternators? Are there even any available?
Powerstroke 6.0
rush24
I haven't found any higher output alternators....but I figured a yellow top and a cap would be good enough...
Eric....Does your Speed have the Bose?? Just curious if it was a pain to get everything hooked up...
2007 Black CX7
SURE Motor Mount...
[/color]
Eclipse
this was in my reg 6i, nonbose
Powerstroke 6.0
rush24
I see...I'm just trying to figure out how much of a pain this would be if I take it on myself...
2007 Black CX7
SURE Motor Mount...
[/color]
Eclipse
keeping the stock speakers? easy as tapping the low level input on the Bose amp for your sub amp..
Powerstroke 6.0
rush24
Postby rush24 » Sat Dec 05, 2009 9:14
Yup..keeping the Bose speakers...just adding a HU...the amp and sub..
I'm actually happy with the sound of the Bose speakers...just not the bass..
2007 Black CX7
SURE Motor Mount...
[/color]
LaginWagon
Postby LaginWagon » Sat Dec 05, 2009 9:14
You do realize the OHM rating on the crappy Blose speakers is abnormal and will sound worse with anything but the crappy Blose amp. Just sayin'.
rush24
The Bose amp will still be used....the PAC Mazato adapter allows you to keep the full functions of the Bose when adding a aftermarket HU...
2007 Black CX7
SURE Motor Mount...
[/color]
LaginWagon
rush24 wrote:the PAC Mazato adapter allows you to keep the full functions of the Bose when adding a aftermarket HU...
Linky please, I'm interested. Also steering wheel controls?
Eclipse
Postby Eclipse » Sat Dec 05, 2009 9:14
there are steering wheel control adapters made for our car, also made by PAC..
Powerstroke 6.0
rush24
Postby rush24 » Sun Dec 06, 2009 9:14
Just head over to crutchfield.com and search for PAC SWI....there are 3 or 4 adapters for different HU...as far as the MAZATO adapter...it's advertised only for the CX-7 and CX-9...but u never know..
2007 Black CX7
SURE Motor Mount...
[/color]
Postby dommo_g » Sun Dec 06, 2009 9:14
You know the battery is only used to power the system when the engine is off, right? With that said, the factory Panasonic batteries are crap to begin with, so anything decent will be an improvement, especially the Optima.
rush24
Ya....I know....but like you said the Mazda batteries are crap....Mine is on the way out now......I'm trying to decide between a Red Top or a Yellow Top...there is about a $100 difference....I've seen a few cars with systems run a Red Top and work fine....Any suggestions??
2007 Black CX7
SURE Motor Mount...
[/color]
