Keyless Problems
Keyless Problems
Postby tbot » Fri Jul 09, 2010 9:14
So just the other day my keyless entry started acting up. The lock button doesn't work anymore on either remotes. Tried new batteries, tried reprogramming the remotes, disconnecting the car battery for a while, all to no avail. The strange thing, the unlock and panic buttons work! I have no idea what else to look at now, I've searched online for a couple hours and didn't find any thing pertaining to my problem and tried a couple things that "sorta" related which didn't help.
Anyone have any incite, I'd rather not take it to the dealer so they can rape me on cost :(.
Postby GR-8 » Fri Jul 09, 2010 9:14
If Batteries and re-programming didn't work I say you need new fobs.
why would both stop working tho...at the same time...that's what doesn't make sense to me.
rush24
Postby rush24 » Fri Jul 09, 2010 9:14
Did you check fuses?? Mazda has had issues with keyless entry and remote start systems blowing fuses.....
2007 Black CX7
Apexcone Raptor 6000k HID...
3" DP back Exhaust System
SURE Motor Mount...
[/color]
Eclipse
Postby Eclipse » Fri Jul 09, 2010 9:14
it relates to ecu programming. The ecu needs to be reprogrammed. Had the same thing happen to me, and Mazda had to reprogram both remotes... and it aint cheap. There is no other remedy
it happened to me before at the same time. thys happend twice to me. The dealer pulled out 2 new fobs and programmed them.
lovely...guess its manual mode for a while lol
Postby Huzer » Fri Jul 09, 2010 9:14
Manual mode is cool, very retro. I've been doing that with my car since the $200 for a new remote/programming from Volvo is money better spent elsewhere.
Just re-read the first post. Intresting that your panic and unlock buttons work. Nothing wrong with the button itself? I'm not sure what your keyless is. Is it a normal fob or is it the card keyless? If you open it and press the lock button on the main board does it work?
GTConversion
Postby GTConversion » Fri Jul 09, 2010 9:14
How do you know lock isn't working? The locks aren't locking, or the lights aren't blinking? If it's the latter, you have a door or latch not fully closed. If it's the former, then I've got nothing..
GTConversion wrote:How do you know lock isn't working? The locks aren't locking, or the lights aren't blinking? If it's the latter, you have a door or latch not fully closed. If it's the former, then I've got nothing..
Good points, good points.
Postby tbot » Sat Jul 10, 2010 9:14
um thee locks aren't locking and lights aren't flashing for either lock or unlock. strangely they just started working again...I have no clue what the hell is going on haha.
