Well, I picked up the RX8 Friday late after having a Mishi Rad and Mazmart ReMedy water pump install. The engine runs super cool in traffic and on the Hiway now. However,(there is always a however) when I took it to the mountains things changed. It was running with A/C on at 203-212 degrees in traffic and on the road. When I started climbing the hills in 8-10% grades in third gear at around 4g rpm it started to get warm on me again. It reached 232 with A/C on and 225 with it off at the top of the mountain. The ambient temp was 80-85 degrees. I was concerned about this after all the work. I won't be climbing mountains with it very often. I'll wait and see what happens at 95 degrees ambient in traffic.
One thing that really pissed me off. I took it to Mazda of Lakewood 3 weeks ago and had a new thermostat installed. The tech told me the fans were working as advertised. He also took it in traffic and it never overheated. Shortly after that I had it at 240 degrees in traffic. Thats why the new rad and pump. The mech that I normally take all my jap cars to and that I trust said the primary fan was disconnected. Now tell me how a Mazda dealership tech can test the fans and say they are o.k. with one unplugged???? I called them back after discovering this and the tech swore they were working according to his computer. Someone is lying! My mechanic had no reason to say the fan was unplugged. He simply had nothing to gain from it. He hooked it up and it checked out o.k. This is the kind of shit that really pisses me off about dealerships.
__________________
New Rad and Re-Medy pump for the RX8
So you took the car in the mountains after the primary fan was reconnected and it still got hot? Not that I'm surprised, I think running in the mountains makes pretty much all rotaries overheat or come close at least. If you can get a vented hood, I would suggest that. Along with maybe finding some other ways of improving cooling. Maybe Water Wetter, run the fans constantly, etc.
Back in 08 when we went on a cruise in the mountains, mine started getting really hot. Back then I had a stock radiator and regular hood. Now have a VMIC/radiator setup and a vented hood and my temps are actually too low haha. I haven't had it up in the mountains in Denver again yet to see how it compares, but I've had it in the mountains down here and it's great.
speedjunkie wrote:So you took the car in the mountains after the primary fan was reconnected and it still got hot? Not that I'm surprised, I think running in the mountains makes pretty much all rotaries overheat or come close at least. If you can get a vented hood, I would suggest that. Along with maybe finding some other ways of improving cooling. Maybe Water Wetter, run the fans constantly, etc.
Didn't want to pull your quote, but that's the only way I can submit a reply
I think your right about the mountains and overheating. My initial results makes me think my in-town heating problem is solved. It's supposed to hit the 90's later in the week. I'm sure I'll find out. I am now using a 60/40 water/coolant with waterwetter.
I think the vented hoods are really sharp. Where can you get them?????
christi
I'm thinking rotaries fail for running in the mountains. even with my rebuilt motor is still ran hot and I didny even get to the entrance to mt Evans. I'm thinking my issue, like yours, I need a radiator. However a open ventilated hood will be very good, I agree with Eric. Good luck to you however.
13B n/a Street Port
Goopy performance
2005 Mazda 3
nothin' but stock love.
13B n/a Street Port
Goopy performance
2005 Mazda 3
I don't think I had ever heard of an RX-8 running hot in the mountains, so it was kind of a surprise to me.
For a vented hood, I'm not sure for you guys where you can get a good one but just do a google search or whatever for RX-8 vented hood or carbon fiber hood (since most CF hoods seem to be vented). I can tell you from experience, stay away from VIS. The hood I have now is from VIS and it fit like shit, took so much work to make it fit right and it's still not great.
I know that my RX-8 would run hot in the city pre-turbo and even in the mountains. I could just tell when it was hot because it drove like shit. Never had a way to actually see what temp it was really at till I got the AP and turbo charged it. Kinda surprised that your running that hot N/A. I took the 8 up to black hawk 2 weeks back through 6th and I hit max 220 that was in traffic with people going slow and using their brakes going up hill. We were literally going 25MPH uphill for a few miles. Probably 85 degree ambient temp. Once I broke loose from the pack (Boost and Passing lanes
) and got a nice pace going I dropped between 210 and 202. Would go up when I would get into boost and have fun.
It's scary running those temps. Hopefully I find another job and make money to actually buy the parts and radiator I need to fully tune and get this 8 %100 finished. To bad my "Mechanic" and I are fighting. I don't have access to most of the tools I'll need or a lift anymore. Who knows when this will get finished.
) and got a nice pace going I dropped between 210 and 202. Would go up when I would get into boost and have fun. It's scary running those temps. Hopefully I find another job and make money to actually buy the parts and radiator I need to fully tune and get this 8 %100 finished. To bad my "Mechanic" and I are fighting. I don't have access to most of the tools I'll need or a lift anymore. Who knows when this will get finished.
Well, it took longer than I thought to actually get to a real computer, but here we go:
I have not had wonderful luck with Mishimoto radiators, had much better luck with Fluidyne and Koyo rads. That said, a new radiator will usually work regardless of brand
The race cars use a modified coolant neck/thermostat housing which helps to keep the car cool. Its a pretty simple modification but I am not sure how it would work on a street car.
At St Pete in 95deg weather we were able to maintain 180 temps unless in traffic, where temps would rise to maybe 215 untill we stuck the nose out in traffic. Again, not sure how this applies to a street car except that running hard as long as there was some air we were fine.
As to temps-
200 is really close to too high, and it is slowly killing the motor. 230 is time to shut the thing off and let it cool off. Yes, I am aware of Mazdas way high fan settings and thermostat, both of which were dictated by fuel economy and emissions, and both of which need changing if you drive your car much further than the corner store.
A vented hood might help and be really cool looking, but we arent allowed to use them
As to temps-
Dan,
I'm pretty interested in the modified coolant neck/thermo housing. Do you have one on any of your cars I can look at or know how to get my hands on one? The new rad seems to be fine. I have to wait til the ambient temps get a little higher and get stuck in traffic to make sure. My initial impression is the slow traffic issue is good to go. Yesterday morning I went down marshall street in Arvada from 62nd and went to I-70 that way. About 2.5 miles. I was at 203 degrees when I hit lamar and I-70. I got on it a bit going up the on-ramp. Topped out at 8500 in 2nd, backed out of it at 70 mph when I got onto I-70. The temp shot up to 216 in about 20-30 seconds and died back down to about 205 within about a mile. Just seems like a quick spike to me in such a short time period. I can only assume my Accessport is accurate. I was running it in Stage 1. BTW I set it back to stock mode at lunch time to see if that makes a diff. I'll try that again today. Like GR-8 said "it ran like shit" in the hills when it was hot. I backed way out of it in the hills. A couple times recently I have smelled a slight coolant odor under the hood (not inside). I have never seen any coolant on the ground or anywhere else in the eng compt. Another mech told me to pressure ck the rad cap. I just went and ordered a new one yesterday. It'll be here tomorrow. Mech said there may be a little pressure loss due to the cap that might contribute a little to the problem. I'd rather buy a $20. cap than another rad or have another dealer mech give me some shitty info for a phenominal price.
Huzer wrote:If you have an AP, you can download the AccessRACE (AccessTUNER, whatever the heck the customer version is called) software and modify the fan temp settings. Stock, they come on at ridiculously high temps.
It's actually easy to do.
Huzer, I bought the AP from a private guy, not Cobb. Will they let me download it anyways? I thought I used to have it on there. I don't remember seeing it lately. I haven't deleted it or anything.
Try this link: http://accessecu.com/register/cobb.php
I can show you how to change the fan settings, it's stupid easy.
In regards to radiators, the RX-8 seems rather finicky about what heat exchanger you use. Granted, I've heard minimal feedback on Mishimoto radiators, but they are mostly re-badged Chinese rads. KOYO rads are decent but actually not that great on the RX-8 because the limit airflow and cause an "air dam".
The radiator of choice for the RX-8 is Griffin, PWR, or Ron Davis. None of these are cheap options, however, but you will have a hard time overheating with one. My old RX-8 was turbo'ed with a giant FMIC core blocking my Griffin radiator, and I was running in Phoenix, Arizona, and I had a hard time breaking 200*F coolant temps. I only could on super hot days (115*F plus ambient temps) with the A/C on, and still I wouldn't go over 205*F or so.
chickenwafer wrote:I can show you how to change the fan settings, it's stupid easy.
And I'm still saving up for the Griffin.
Maybe next summer?Who is online
