microtech ecu tune
boosted12a
microtech ecu tune
Postby boosted12a » Thu Sep 08, 2011 9:14
i finally got my turbo rx7 here but its running like a NA car no boost and its getting flooded i need someone that knows how to tune microtech ECU on Rotary-Turbo cars. :confused:
Postby Learjet45 » Thu Sep 08, 2011 9:14
Idk if he knows about microtech ecus or anything, but chickenwafer seems to be the guy on the forums for rotary tuning. He might be able to help. But he is also really far away from you up in Loveland.
Postby iani1.1 » Thu Sep 08, 2011 9:14
loveland isnt that far... maybe it is lol.
locally in springs theres not really anybody.
Postby chickenwafer » Fri Sep 09, 2011 9:14
I've done some Microtech tuning with the Interceptor-X for my old RX-8, but I have to admit, I absolutely LOATHE Microtech. No offense intended, but they are about 5-8 years behind all other major EMS' on the market, if not further. And the ability to not create maps offline is just stupid.
I would seriously, strongly advise to upgrading to a Haltech when you can. Much better setup IMO.
boosted12a
Postby boosted12a » Sat Sep 10, 2011 9:14
chickenwafer wrote:I've done some Microtech tuning with the Interceptor-X for my old RX-8, but I have to admit, I absolutely LOATHE Microtech. No offense intended, but they are about 5-8 years behind all other major EMS' on the market, if not further. And the ability to not create maps offline is just stupid.
most of the faster rotary from Puerto Rico and Australia use microtech running 6 and 7 sec 1/4 mile and in Fl everyone uses microtech. my car dyno 338 WHP for a 12a thats really good !!!! but the altitude is making my car gets flooded i tried changing settings to make car run leaner but still doing it.
Postby chickenwafer » Sat Sep 10, 2011 9:14
And that's the problem with the Microtech, it can't compensate in anyway whatsoever for atmospheric or environmental changes. With a good ECU like a Haltech, AEM, MoTeC, etc you can have correction factors for multiple tables to compensate for those changes.
I'm not saying the Microtech won't work great when it's tuned right, but if the weather drastically changes or you go on a road trip that involves altitude change, you're screwed.
boosted12a
chickenwafer wrote:And that's the problem with the Microtech, it can't compensate in anyway whatsoever for atmospheric or environmental changes. With a good ECU like a Haltech, AEM, MoTeC, etc you can have correction factors for multiple tables to compensate for those changes.
do you know how to wire the haltech and how create and load maps? also which haltech would i need? i saw one on ebay new for $1000 shipped
boosted12a
Postby boosted12a » Sun Sep 11, 2011 9:14
would this one work? http://cgi.ebay.com/ebaymotors/Haltech-Mazda-RX-7-13B-Sprint-RE-stand-alone-ECU-kit-_W0QQcmdZViewItemQQ_trkparmsZalgoQ3dLVIQ26ituQ3dUCIQ26otnQ3d5Q26poQ3dLVIQ26psQ3d63Q26clkidQ3d2705531191284586715QQ_trksidZp5197Q2em7QQitemZ110587222014#ht_4382wt_862
Postby chickenwafer » Sun Sep 11, 2011 9:14
It should work, I'm just not positive what kind of timing wheel setup you have? I haven't messed with 12a's much haha. If it's an FC or FD style timing wheel it will work on that Haltech.
As far as wiring, I've helped wire some E8's and E11v2's (older Haltech's) and back then you could only use GM style sensors but I've heard Haltech has opened up their sensor compatibility so you should be able to keep most OEM sensors. Worst case you might need to change your timing wheel to an FC or FD wheel and sensor(s). Other than that it's just connecting wires and making the lead look nice.
boosted12a
chickenwafer wrote:It should work, I'm just not positive what kind of timing wheel setup you have? I haven't messed with 12a's much haha. If it's an FC or FD style timing wheel it will work on that Haltech.
im using FC timing wheel and Gm sensors on my 12a
Then that Sprint RE should work great, no problem.
eliminster
Postby eliminster » Wed Sep 14, 2011 9:14
i have to agree that almost all the 7's in Florida use microtech, bought mine from a guy down there with a microtech already installed, haven't had money to upgrade to something i would prefer, and while it does make incredible hp numbers not just peak but throughout the band, i made up to 350 before we detuned it to a nicer 300 hp so i could run 91 octane down there if i had to, i have defiantly notice it doesn't like the elevation here in the springs. It still has a serious kick when it goes into boost but due to a hole in one of the couplers i have a boost leak that reared its nasty head and stole 500rpm from my max boost range. Need to get a new coupler and a new tune, just need to find someone i trust enough to do the tune cause i have seen to many retards destroy apex seals running it too lean, took me 2 years to find a tuner in GA that i trusted enough to tun my car.
boosted12a
Postby boosted12a » Wed Sep 14, 2011 9:14
eliminster wrote:i have to agree that almost all the 7's in Florida use microtech, bought mine from a guy down there with a microtech already installed, haven't had money to upgrade to something i would prefer, and while it does make incredible hp numbers not just peak but throughout the band, i made up to 350 before we detuned it to a nicer 300 hp so i could run 91 octane down there if i had to, i have defiantly notice it doesn't like the elevation here in the springs. It still has a serious kick when it goes into boost but due to a hole in one of the couplers i have a boost leak that reared its nasty head and stole 500rpm from my max boost range. Need to get a new coupler and a new tune, just need to find someone i trust enough to do the tune cause i have seen to many retards destroy apex seals running it too lean, took me 2 years to find a tuner in GA that i trusted enough to tun my car.
i just spent 8k in my engine, turbo, fuel system and microtech. in Fl the car was a beast.
Postby Learjet45 » Wed Sep 14, 2011 9:14
I would definitely trust chickenwafer do to a tune. It seems like he is always going around helping out other 7 owners get their issues figured out.
eliminster
Postby eliminster » Thu Sep 15, 2011 9:14
i spent 3k on my rebuild after an unfortunate meeting of my oil cooler line and a bouncing rock in heavy florida traffic. Yeah i have to agree a 12a pushing 300hp is pretty beastly, i noticed a little loss of power coming up here but not what i would call running like a na car by any means, used to own a gen 2 na and they are no where near as fast down in ga as my car is up here. I have to say i am probably laying down at least 250hp min still even up here.
87 red rx7
running 13b re cosmo motor
03 yellow wrx
yes it is a stock color
00 black s10 zr2
Users browsing this forum: No registered users and 135 guests
