Trouble codes :(
Speed3
Trouble codes :(
Postby Speed3 » Sun Sep 11, 2011 9:14
I got these codes just now
PCM#
## P0455 (evaporation emission control system leak detected (gross leak))
IC
## U2064
Someone help me out soon please. Hopefully it's not bad
2007 Mazdaspeed 3
Postby ~Barn~ » Sun Sep 11, 2011 9:14
I don't know what to tell you, as far as troubleshooting them, but I have an OBDII scanner, if you just want to come over and reset them. Then again, I just read you'e in Pueblo...
Image 720.935.6438
Speed3
Well I reset it on my accessport. I'm pretty sure the second one is cuz in catless? But I've never seen that first one
2007 Mazdaspeed 3
SecondGenPAt
Postby SecondGenPAt » Sun Sep 11, 2011 9:14
The PO4055 is due to a large leak (above .050") Did you just fill up? is your gas cap loose? that's the most sensible fault. if it is the tighten it and reset your codes. it may come back after a few drive cycles with the same code, then you have a legitimate failure. i can't anything on the U code as that is manufacturer specific. it may just be a readyness code like P1000. but thats just a guess
Speed3
Yep the gas cap was loose thank you hopefully that fixes it!
2007 Mazdaspeed 3
Users browsing this forum: Google [Bot] and 279 guests
