My FC Widebody for sale as a roller
D Walker
Postby D Walker » Tue Jun 12, 2012 9:14
Selling my FC as a roller. This is the car we ran Pikes Peak with in 2010 and is pretty much ready to go racing, needs motor, ecu, wiring, and rear diff.
Includes-
Rollcage
Completely stripped and all insulation etc removed
"tubbed" front wheelwells for cleaance
DTSS eliminators
Energy Suspension poly bushings
Delrin subframe mounts
BC Coilovers
Stainless brake lines
Dual master cylinder setup with brake bias
Fresh reman T2 front brakes, new rotors and Performance Friction 91 pads
t2 rear brakes, drilled rotors
Aluminum fuel lines
Walbro in-tank pump
Aluminum radiator support
NASCAR aluminum radiator
large oil cooler mounted drivers side
widebody fenders
vented FG hood- vents are "top secret" style
hood pins
car weighed 2100lbs with the S5 motor
3" SS exhaust inc downpipe goes with the car
T2 trans in great shape
Kirkey aluminum seat with brace
Racequip belts in date
Teamtech window net
Autometer 10K tach, water temp, oil pressure, and possible a few other gauges included but not mounted/installed
NO MOTOR
NO ECU
NO REAR DIFF
I do have and will include a broken (needs ring and pinion) T2 LSD rear end and a spare t2 clutch type rear diff (diff ONLY, no R&P)
Looking for $2500 as it sits
Will include a set of Kosei 18x9.5 F3'swith decent tires for an additional $500
Pics are at- http://s218.photobucket.com/albums/cc259/dwalker460/RX7%20Race%20Car/
Car is at my shop in Denver, can ship etc.
