Help?
pyrrhus17
Help?
Postby pyrrhus17 » Mon Jun 25, 2012 9:14
[ATTACH]2353[/ATTACH]
have damage from jack stand how serious is it ? This is someone elses pic .my jack released pressure before I could place my jack stand and dented/crimped the area in the photo between the jack and the stand near where that bolt is in the photo closer to where you are supposed to place the jack . Did i just seriously #### up my car or what ? help a newbie out ? its dented in between the two holes Thank god I had my regular car jack saved the day !!!
I know \Iam a dipshit
Postby I`m Batman » Mon Jun 25, 2012 9:14
I think you're fine unless you're planning to take your chassis apart.
pyrrhus17
No its just a small indentation car seems to drive fine but this is the first car I have worked on so i am paranoid .
Postby chickenwafer » Mon Jun 25, 2012 9:14
You're fine. I've done worse with cars slipping/falling off a jack and hitting a jackstand or the jack itself. That damage is pretty minimal.
KILLER_VIZ
Postby KILLER_VIZ » Mon Jun 25, 2012 9:14
Its over pry you might as well sell the car to @auroraaxela for cheap! or just straight junk it! Lol youll be ok bro, now if the stand went through your floor board then its a problem.
chromal
Postby chromal » Mon Jun 25, 2012 9:14
I wouldn't worry about it, maybe just double check no paint was removed and repaint if you see bare metal to prevent future rust. I have done... far worse... with a car falling off a jack and onto a jackstand (badly). At least you didn't have a hole poked in the floor anywhere. :)
Users browsing this forum: No registered users and 127 guests
