my e85 tune
DJ
my e85 tune
Postby DJ » Sun Jul 28, 2013 9:14
So ive been getting my car tuned on e85 by bills in hr. We have had hell with the stock bcs so i got a hallman but we ran out of time yesterday. We will finish it tomorow. But numbers are 290 and 324 thats at 18 psi and running supppppperrrrrr rich. Were at 10.2 afr so were gonna lean it out more so we should see low 300's hp and 350 360 tq
~David
2008 Mazdaspeed 3 True Red
PTE 5858
JMF intake manifold
Cpe exhaust manifold
2008 Mazdaspeed 3 Cosmic Blue
vierte
Postby vierte » Mon Jul 29, 2013 9:14
i <3 corn water! keep us posted. would love to see a graph.
DJ
Postby DJ » Mon Jul 29, 2013 9:14
We Will probably be done today
~David
PTE 5858
JMF intake manifold
DJ
Postby DJ » Tue Aug 06, 2013 9:14
on bills mustang dyno I made 290 and 280 on 17 pounds of boost. He then cranked it up to 21 tapering down to 20 at 5900rpm problem with the last dyno pull is I dont have the same phone I did last week so im waiting for him to send me the dyno sheets. But I did pull a larger frame turbo srt4 on e85 I pulled him I raced my buddys sti which on harveys dyno made 380 I beat him bad twice. I ran a fully bolted gen 2 beat him by 4 lengths while spining through 3rd. I ran a e85 tuned evo beat him by 2 lengths. Needless to say its ####ing great
~David
PTE 5858
JMF intake manifold
Postby VRx8 » Tue Aug 06, 2013 9:14
E85 is the shitzz. Must if you want to make safe power. Some people run no intercooler with e85 also eliminates the need for Water Injection.
Postby erod550 » Wed Aug 07, 2013 9:14
Sweet. When I finally get around to supercharging the Stang I will be making the switch to corn as well.
DJ
Postby DJ » Tue Sep 03, 2013 9:14
Ill hopefully get a fmic this week. Thats the hope at least so more power...
~David
PTE 5858
JMF intake manifold
Mortose
Postby Mortose » Tue Sep 03, 2013 9:14
are these numbers corrected?
You have plenty of room if they are. I was running 360/426 (corrected) on a corn tune with my K04.
Question: you signiture made me think, are you running 100% E85, or a mix?
DJ
Postby DJ » Fri Sep 13, 2013 9:14
100% corn. and corrected. its a very low reading mustang dyno
~David
PTE 5858
JMF intake manifold
DJ
if your going to question my 100% e85 in my car. i tear down my fuel pump every month to clean the shit out of it.
~David
PTE 5858
JMF intake manifold
DJ
whose dyno did u make those numbers on
~David
PTE 5858
JMF intake manifold
Mortose
Postby Mortose » Fri Sep 13, 2013 9:14
It was down here at UPP in the springs.
and that is dedication to pull your pump appart. Don't forget about the fuel lines. They aren't very big fans of corn juice.
Edit: here is my dyno chart
Postby erod550 » Fri Sep 13, 2013 9:14
1.25 CF? There's no way you're losing 25% power, even at altitude, with a turbo car. Even my NA car is only down 18-20% up here.
But I guess as long as you're consistent and just using it to measure before and after gains, then it's still useful info. But no way you have that much power at sea level.
Mortose
Lol. It's fairly close, probably about 15-20 hp difference. From what I have seen of other cars at sea level, but yes, it's only a tool for measuring gains. I'm going to hop on the same Dyno once my new clutch is in to see the difference between my ko4 and my 2867.
DJ
Postby DJ » Sun Jan 19, 2014 9:14
Im now on water meth I had kept getting fuel. So im in 91 meth on a bnr stage 3 turbo it made 384 and 406
~David
PTE 5858
JMF intake manifold
Users browsing this forum: No registered users and 131 guests
