Best inexpensive boost gauge
Postby RX-7 Chris » Fri Jan 27, 2017 9:14
What is the recommendation for a quality inexpensive boost gauge? It doesn't need to go over 15 psi.
Re: Best inexpensive boost gauge
Postby Shadowden » Fri Jan 27, 2017 9:14
I haven't had any issues with my prosport oil temp gauge. When I replaced the sending unit (sensor), the oil tem did read slightly differently than the old one. Same general temp though. The clock I installed is okay too. I need to pull my pillar pod and tighten everything up better or ditch it all together.
$crillaTor
Postby $crillaTor » Fri Jan 27, 2017 9:14
I have Prosport gauges as well. Never had issues.
Postby RX-7 Chris » Mon Jan 30, 2017 9:14
Thanks for the info. I'm not too worried about it being perfectly accurate honestly. I'm not going to be pushing the boost past 12, stock is 7. I want the gauge more so I know if I have leak in the system.
Postby chickenwafer » Sun Feb 05, 2017 9:14
I've always preferred mechanical boost gauges, they react much quicker than most electric gauges (especially cheaper units), are cheaper, and dead nuts reliable and accurate.
I like AutoMeter but really any mechanical boost gauge is pretty darn good
http://www.jegs.com/i/Auto-Meter/105/2614/10002/-1
Postby Shadowden » Mon Feb 06, 2017 9:14
I like the simplicity of that gauge. I am eventually moving my gauges somewhere else (tired of being asked if it is turboed) and want small simple gauges. The option I really want isn't likely to happen any time soon (defi system).
http://www.evasivemotorsports.com/mm5/m ... ADVANCE-ZD
