Engine build
DJ
Engine build
Postby DJ » Sat Feb 04, 2017 9:14
Since my last login I built the engine in my ms3 included in the build sheet is a few other mods unrelated to the engine. I'm not done yet I still need to add my secondary fuel system but I will get there at some point.
Tr8 fmic, jbr cold pipe, tial q bov, htp under routing, cpe exhaust manifold, tial 44mm wastegate, pte 5858 with ported s cover, htp 4" intake, cpe egr block, kozmic dump tube, kozmic occ, jmf intake manifold, crower 66# valve Springs with titanium retainers, manly 88mm pistons, k1 rods with arp bolts, jbr oil baffle with balance shaft delete, keyed crank, pinned cams, arp L19 studs, act street light flywheel with 6 puck clutch, kozmic downpipe for percision V band turbo, AutoTech hpfp, apv2, hks cat back, jpr pmm and Tmm, cobb rmm, adapted performance engine covers, whiteline sway bar endlinks, Koni yellow struts, hr Springs, custom intercooler sprayer, led interior lights, yellow fog lamps, fan on demand switch, cobb 3 port ebcs, Bosch 3.5 bar map, hawk slotted rotors, aeromotive 325 stealth fuel pump. Oil filter Spin on conversion.
Theres more but who can remember it all
~David
2008 Mazdaspeed 3 True Red
PTE 5858
JMF intake manifold
Cpe exhaust manifold
2008 Mazdaspeed 3 Cosmic Blue
Re: Engine build
Postby Shadowden » Mon Feb 06, 2017 9:14
Nice. That is a lot of build. Were you at Cars and Coffee this past Saturday? Quite a few Speed3 there.
Re: Engine build
Postby Number2 » Tue Feb 07, 2017 9:14
That's a lot of acronyms.
