Number2 wrote:I like the ceramic coated black. Looks good!
Thanks! I was really pleased with how it turned out too.
geo2maz wrote:keep an eye on the duct-tank-tape, after a couple of hot summers the glue can melt and turn into a sticky mess which you don't want on your engine...
(I used to have a big duct-tape patch under my dash in my old car, after a few years on a hot day it kind of melted off and the glue got on my shoes and carpet, twas gross)
bullet on your desk? really?
Well I'm not sure how hot it will get because it won't be in direct sunlight or getting heat from the engine bay, but I guess it's still something to watch out for.
Well, we're a military household. If you DON'T find ammo anywhere in the house, something is wrong lol.
erod550 wrote:Yea because duct tape looks sooo much better than them turning yellow... LOL
RX-7 Chris wrote:That was my thought.
Dange wrote:i gotta agree, no offense intended. but the ducttape looks like your tank cracked and you were too cheap to buy a new one and fixed the leak with tape...
with all the purdy bits you just got coated, its just not gonna look right
Well guys, these things can't even be seen, so it's really just for protection. I only have part of my fender liner left in front of the wheel (the rest was cut out), which is where these are, and I don't want the tire throwing things onto them and damaging them prematurely. I started only wrapping that area directly in front of the tire and decided to do the whole thing because the front of it is directly behind the oil coolers and I've had problems before with getting them to stop seeping oil. So the fact that the duct tape won't even be seen makes your point a little moot. I mainly did this in case I wanted to sell them in the future or whatever, to keep them as nice as possible. The sticky mess from the duct tape would be my biggest worry at that point but that could be cleaned off with some solvent. The only part that's visible is the filler neck, which I didn't wrap. And the fact that it's bright white tells you that it's new, which is what I was going for. And I'm not sure duct tape could fix a leak LOL.
There IS a method to my madness guys
This is almost along the same lines as wrapping the wiring harness in reflective tape. When I removed the tape a couple months ago to make it a single turbo harness, after about 25k miles the harness was still in brand new shape, whereas if it hadn't been wrapped the plastic shielding would have already started hardening. Parts for this car are expensive and I'd like to make them last as long as possible, sometimes even at the expense of beauty (but not even in this case since they won't be in view).
