Some may call it overkill...
Postby speedjunkie » Tue Mar 01, 2011 9:14
...some may call it paranoia...
I call it protecting my investment. LOL OK, maybe it's paranoia.
I paid $150 for new coolant overflow and windshield washer fluid tanks and I don't want them damaged and I want them to go as long as possible before yellowing. Not sure if duct tape will help but I'm trying it anyway haha.
Also, here is the pic I promised of the stuff I got powder coated and ceramic coated.
Postby Number2 » Tue Mar 01, 2011 9:14
I like the ceramic coated black. Looks good!
Postby erod550 » Tue Mar 01, 2011 9:14
Yea because duct tape looks sooo much better than them turning yellow... LOL
Postby geo2maz » Tue Mar 01, 2011 9:14
keep an eye on the duct-tank-tape, after a couple of hot summers the glue can melt and turn into a sticky mess which you don't want on your engine...
(I used to have a big duct-tape patch under my dash in my old car, after a few years on a hot day it kind of melted off and the glue got on my shoes and carpet, twas gross)
bullet on your desk? really? :)
Postby RX-7 Chris » Tue Mar 01, 2011 9:14
erod550 wrote:Yea because duct tape looks sooo much better than them turning yellow... LOL
That was my thought.
Dange
Postby Dange » Tue Mar 01, 2011 9:14
i gotta agree, no offense intended. but the ducttape looks like your tank cracked and you were too cheap to buy a new one and fixed the leak with tape...
with all the purdy bits you just got coated, its just not gonna look right
04MSMGT
Number2 wrote:I like the ceramic coated black. Looks good!
Thanks! I was really pleased with how it turned out too.
geo2maz wrote:keep an eye on the duct-tank-tape, after a couple of hot summers the glue can melt and turn into a sticky mess which you don't want on your engine...
Well I'm not sure how hot it will get because it won't be in direct sunlight or getting heat from the engine bay, but I guess it's still something to watch out for.
Well, we're a military household. If you DON'T find ammo anywhere in the house, something is wrong lol.
RX-7 Chris wrote:That was my thought.
Dange wrote:i gotta agree, no offense intended. but the ducttape looks like your tank cracked and you were too cheap to buy a new one and fixed the leak with tape...
Well guys, these things can't even be seen, so it's really just for protection. I only have part of my fender liner left in front of the wheel (the rest was cut out), which is where these are, and I don't want the tire throwing things onto them and damaging them prematurely. I started only wrapping that area directly in front of the tire and decided to do the whole thing because the front of it is directly behind the oil coolers and I've had problems before with getting them to stop seeping oil. So the fact that the duct tape won't even be seen makes your point a little moot. I mainly did this in case I wanted to sell them in the future or whatever, to keep them as nice as possible. The sticky mess from the duct tape would be my biggest worry at that point but that could be cleaned off with some solvent. The only part that's visible is the filler neck, which I didn't wrap. And the fact that it's bright white tells you that it's new, which is what I was going for. And I'm not sure duct tape could fix a leak LOL.
There IS a method to my madness guys ;)
This is almost along the same lines as wrapping the wiring harness in reflective tape. When I removed the tape a couple months ago to make it a single turbo harness, after about 25k miles the harness was still in brand new shape, whereas if it hadn't been wrapped the plastic shielding would have already started hardening. Parts for this car are expensive and I'd like to make them last as long as possible, sometimes even at the expense of beauty (but not even in this case since they won't be in view).
Postby chickenwafer » Tue Mar 01, 2011 9:14
I like it mang!
I plan on ditching my coolant overflow bottle and just letting the overflow (if there is any, mine is currently dry) run to a hose pointed at the ground. That's what I did on my RX-8
Postby speedjunkie » Wed Mar 02, 2011 9:14
Really? I never thought of doing that. I guess that would clean it up a bit haha.
On the same note, I was thinking about getting an oil catch can. Right now I just have a hose pointed to the ground from the filler neck but it only goes halfway down my engine and it's making a mess all over the spark plugs and everything on that side. I think it might have contributed to looking like the oil pan was seeping too, and I'm not cool with that cause that made me want the brace haha.
Postby RX-7 Chris » Wed Mar 02, 2011 9:14
The only thing about ditching the coolant overglow is you won't be able to race without one.
Dange
Postby Dange » Wed Mar 02, 2011 9:14
hmm, i didnt know that, i thought it was like most cars where the bottles sit up next to the engine in plain view.... in that case, its not bad at all. and will probably protect em
04MSMGT
Postby erod550 » Wed Mar 02, 2011 9:14
^ What he said.
Postby iani1.1 » Wed Mar 02, 2011 9:14
RX-7 Chris wrote:The only thing about ditching the coolant overglow is you won't be able to race without one.
sad but true. they wouldnt let me on bandimere cause the cap to the overflow was cracked
Oh that sucks. I can totally see why though. Same reason I need an oil catch can haha.
Dange wrote:hmm, i didnt know that, i thought it was like most cars where the bottles sit up next to the engine in plain view.... in that case, its not bad at all. and will probably protect em
erod550 wrote:^ What he said.
Yeah I definitely wouldn't have wrapped them in duct tape if they were visible lol. You can see the top of the tank from the engine bay but it's still not too visible, and my 2 cycle oil reservoir is blocking view on the driver's side and if I ever install an air box for the filter it will block the view on the passenger side, so no biggie.
iani1.1 wrote:sad but true. they wouldnt let me on bandimere cause the cap to the overflow was cracked
Should have wrapped it with duct tape LOL.
Postby chickenwafer » Wed Mar 02, 2011 9:14
I was allowed at Speed World drag strip in Phoenix with my overflow hose pointed at the ground. The RX-8 is actually setup like that from the factory. Not sure if it makes a difference because of the expansion tank or not.
The RX-8 has a BRILLIANT design where the AST overflow hose is pointed right at the electrical harness for the radiator fans. Makes them fail all the time.
Users browsing this forum: No registered users and 126 guests
