fender rolling....
Body kits, bling, lights
zlyricist
fender rolling....
Postby zlyricist » Mon May 03, 2010 9:14
so i just put bigger wheels on my 6, and its rubbing on all four, i need to flare them out maybe 1/8-1/4" all around
now i know there is tools that i can get to do this, but if i can have a shop do it nice and not too expensive id rather go that route. im pretty clueless as to where i would go for something like this, so any help would be appreciated!
91 MX6 GT - SHO swap on backburner
02 Maxima GLE - daily
Postby chickenwafer » Mon May 03, 2010 9:14
Any body shop should be able to do it for you, and won't cost too much. You can easily do it yourself with a fender roller tool or a heat gun, baseball bat and lube lol
Postby bellalyssa » Mon May 03, 2010 9:14
SCR Performance has the ability to do this.
http://www.scrperformance.com
LaginWagon
Postby LaginWagon » Mon May 03, 2010 9:14
chickenwafer wrote:Any body shop should be able to do it for you, and won't cost too much. You can easily do it yourself with a fender roller tool or a heat gun, baseball bat and lube lol
2nd, baseball bat is an old and good trick. You can also use a hammer handle. I have used both in the past with great results. Be aware of the possibilty of the paint chipping. That's what the heat gun will help with prior to "rolling".
Postby RX-7 Chris » Mon May 03, 2010 9:14
LaginWagon wrote:2nd, baseball bat is an old and good trick. You can also use a hammer handle. I have used both in the past with great results. Be aware of the possibilty of the paint chipping. That's what the heat gun will help with prior to "rolling".
it does work good, that is what we did with my Dad's posche.
The trick to the baseball method is to just take your time and thoroughly heat up the paint. I try to get the surface to at least 150*F (measured with my infrared temp gun). I used the baseball bat method on the rear fenders of my RX-8 and it was easy. I the used the Eastwood Fender Finisher tool (basically a pair of a big pliers with rubber teeth) to do the front fenders.
I used an aluminum bat but I heard wooden bats work better? Not sure...
It was easy and turned out good, but this time around on the FD I'm using a proper roller...
LaginWagon
Not sure, I used a wooden one, lol. I guess the benefit (if any at all) to the wooden bat is it won't slide on metal as easy as an aluminum bat?
Gmoney
Postby Gmoney » Mon May 03, 2010 9:14
I am not sure of the baseball bat technique:huh:, but have done two cars with the proper eastwood roller. Here is the link to the previous thread.........any ?'s just give me a shout through PM
Greg
http://www.coloradomazdaclub.com/forums/showthread.php?t=3382&highlight=fender+rolling
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*RPM LED Side/Rear Markers
*SU Rear Engine mount
*Cp-e Rear Diff Mount
*TurboSmart MBC
Postby iani1.1 » Mon May 03, 2010 9:14
yea the baseball bat is a little sketch and you gotta take your time. did mine with a easton lol
PXRdriFT
Postby PXRdriFT » Tue May 04, 2010 9:14
Anyone have a roller?
deepSpeedMS3
Postby deepSpeedMS3 » Tue May 04, 2010 9:14
B) deepSpeed MS3 B)
Gmoney
Postby Gmoney » Tue May 04, 2010 9:14
PXRdriFT wrote:Anyone have a roller?
Click on the link I posted and all the contact info is there of a place on south broadway(denver).....
Sounds like there is a lot of interest in this, you all should put together a meet and just rent the tool and do a bunch of cars.
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
rmeeker13
Postby rmeeker13 » Tue May 04, 2010 9:14
I did mine with a piece of 2'' pipe...but i wouldnt recomend it!
Postby Ranger » Tue May 04, 2010 9:14
I wouldn't use a baseball bat personally. I've done all my cars with a cheapo harbor freight heat gun, a hard rubber mallet, and a board wrapped in cloth. Works great, just take your time :)
...but a real roller is still best.
zlyricist
Postby zlyricist » Wed May 05, 2010 9:14
well thanks for the replies. im not too sure which way to go yet.....its not going to be show quality but i would like it to look nice. im a cheap ***. but ive seen what looks like great results on the net with the baseball bat trick lol........
here she is. hopefully will get my turbo kit on here soon, then its on with the mazdaspeed lip kit and to the paint booth!
