Rotary Ford Cortina Project
Postby RX-7 Chris » Thu May 05, 2011 9:14
I'm thinking about a possible new project to work on with my Dad. Since I haven't had any luck so far selling my motor, I've been thinking of something to do with it. I will still keep the motor for sale but continue to look into this.
A friend of mine has a complete 1965 Ford Cortina that actually runs. The front brakes are seized completely and the clutch is shot. It is a 2 dr base model. The body is in very good shape with very little rust. The interior is completely shot. The fuel system is completely rusted out.
I'm thinking of installing the 12A out of the black car with tranny, fuel cell, race buckets, etc. I'd remove the interior except the dash and install a roll bar. The hardest part is going to be the suspension.
Here is some info:
http://www.cortina-mk1.com/sr20.php
the car looks like this one just needs paint and body work:
[ame="http://www.youtube.com/watch?v=m2CveY82mBs&feature=player_embedded"]YouTube - mk1 cortina rotary[/ame]
ecam8000
Postby ecam8000 » Thu May 05, 2011 9:14
Wow! Big Picture!
Is it the Red car? We had a Lotus Cortina with a 289 in it. I love (louve?!?) the idea. I'll even pitch in and help when you need to fab up mounts and stuff.
If you don't go down that road, I want his Cortina. Might even get a rotory if I can fine one for sale.
Eric
2 Fords 29 & 2000.
99 BMW 328i
THANKS! To all who serve.
the Cortina came with a 1200cc motor with 48.5 bhp @ 4800 rpm and had a top speed of 78 mph. 1,736 lbs
http://www.pixelmatic.com.au/cortina/cortina.html
So a 140whp motor would just scream.
ecam8000 wrote:Wow! Big Picture!
I replaced the big picture.
The mounts themselves look to be fairly easy to fab:
ecam8000
Awesome! When do we start? Do they make louvers for a Cortina? Does it come with a helmet?
Eric
2 Fords 29 & 2000.
99 BMW 328i
Postby Ranger » Wed Jun 01, 2011 9:14
So did you get this thing or what? :D This would be so cool. I don't know how you'd ever get it registered though...
D Walker
Postby D Walker » Wed Jun 01, 2011 9:14
That Cortina is a seriously nice starting place for a vintage racer... all you would need is a Lotus "big valve" engine and away you would go.
Postby RX-7 Chris » Wed Jun 01, 2011 9:14
I haven't done anything with this yet. If I can't sell the engine in the next few months than this is where it will go.
Postby iani1.1 » Wed Jun 01, 2011 9:14
wow DOO IIIT!!!
Postby chickenwafer » Wed Jun 01, 2011 9:14
Do it, do it NOW!
MtnHighRX-7
Postby MtnHighRX-7 » Wed Jun 01, 2011 9:14
Great Idea! Nice vintage project. I think you should go for it Chris.
Postby RX-7 Chris » Wed Jul 13, 2011 9:14
I've been doing a ton more research on this.
I'm looking into this for the rear:
http://www.summitracing.com/parts/CEE-U115/
http://www.summitracing.com/parts/MSR-A28CST-1/
http://www.summitracing.com/parts/MSR-7838/
I have quite a few choices for the rear brakes. I'm still working on the front suspension setup. I want manual R/P steering and coilovers. I'm not sure yet on the front brakes. I'm thinking of using the '83 petals and masters that I already have.
I plan to use a TurboII tranny and starter. I would need a custom driveshaft. I would also need to run all new brake lines and parking brake cables. I already have the SS hard line for the fuel, fuel pump, pressure regulator.
I'm looking at this fuel cell: http://www.summitracing.com/parts/SUM-291215-SD/?rtype=10
I would need to get AN fittings and lines for the rest of the fuel system. I need to look for an aluminum radiator and oil cooler plus hoses and lines.
Autopower sells a roll bar for the car. I also still need to work out seats and safety equipment.
Possible color ideas:
ecam8000
Postby ecam8000 » Wed Jul 13, 2011 9:14
That white with green stripe is the Lotus std. How bout reversing the scheme? I did like the red one at the top. If you like the white, maybe change the stripe color. You're not building a Lotus, you are building something better.
Eric
2 Fords 29 & 2000.
99 BMW 328i
True, I'm not building a Lotus and I did know the white with green was the lotus colors. My motor is red, silver, and black but I could change the color to go with the car if I had to.
I figured this paint job would be a 10' paint job since it is a race car and not a show car.
