LS2 FD Build
^From what I've heard you don't need to cut and splice much of the factory chassis harness at all, just untangle it and cut some tape and you have enough slack to tuck it in most places.
If I had the balls (and the time) I would relocate my battery fuse block and engine fuse block to the rear hatch (where the battery is going). I might do the battery-mounted fuse block but the main fuse block would be a PITA. Look hella clean, though.
- boosted12a
chickenwafer wrote:^From what I've heard you don't need to cut and splice much of the factory chassis harness at all, just untangle it and cut some tape and you have enough slack to tuck it in most places.
I never knew you responded to this haha. Well maybe I'll look at doing this sometime then. I'd love to relocate my fuse and relay blocks too, but I haven't for the same reason haha. I'm just afraid of messing something up and never being able to figure out the wiring problem. I hate wiring problems. I REALLY want to run my IC piping through there though. If someone has a write-up on it I might try it.
boosted12a wrote:looks and sounds good, now you have a reliable FD!!!!
Don't encourage him LOL.
So you used the Hinson kit...and the engine fit without hood modification? Did you get their bump steer correction kit too? The Granny's kit claims it uses stock mounting points, and it doesn't lower the engine mounts, so you don't need bump steer correctors...but it also says the engine will not clear the stock hood, which is lame. My car is pretty low so I think I need bump steer correctors anyway as it is haha. Also, I've been thinking about doing this swap for a while now but I think riding in an LS powered FD would be the decision point for me. Do you ever come up to Denver? I'd love to check your car out.
Users browsing this forum: No registered users and 137 guests
