Tranny Fluid Changed
Postby Stealth01 » Sat Jul 24, 2010 9:14
Got that task done today. Was a little easier than I thought, but a hell of a lot messier. Still, there are now ALMOST 3 quarts of Redline MT-90 goodness in the MTX, and she shifts SMOOTH. Noticeable difference.
That said, the old fluid actually looked pretty good. I think it might have been changed somewhere along the way.
Postby bellalyssa » Sat Jul 24, 2010 9:14
I put MT-90 in mine too. I love it!
Yep, definitely shifts smoother now. But that could just be because the old fluid was...well...old.
Postby iani1.1 » Sun Jul 25, 2010 9:14
yes mt-90 is the good stuff. ill be filling my diff and trans with redline here soon
Postby Shadowden » Mon Dec 19, 2011 9:14
Stealth01 wrote:Got that task done today. Was a little easier than I thought, but a hell of a lot messier. Still, there are now ALMOST 3 quarts of Redline MT-90 goodness in the MTX, and she shifts SMOOTH. Noticeable difference.
How did you approach your change? I think I recall reading two different methods. One using a funnel with a long hose, and another.
Postby RX-7 Chris » Mon Dec 19, 2011 9:14
he isn't really on here anymore.
I use a pump to fill the tranny.
RX-7 Chris wrote:he isn't really on here anymore.
How do you use a pump?
Hose into new tranny bottle, ball pump, and hose to fill hole?
I use one of these from the parts store:
Postby Huzer » Mon Dec 19, 2011 9:14
On the 8, I just popped the shifter off the top and dumped in the fluid. Still have 3 quarts or so sitting in the garage...
Postby Shadowden » Tue Dec 20, 2011 9:14
Seems like I should change the fluis when i put my STS on. Need to see if I can get Redline90 locally.
D Walker possibly?
Postby Huzer » Tue Dec 20, 2011 9:14
You can find it locally. And you can have my 3 QTS if you want it. I picked mine up at http://www.3rauto.com/
Huzer wrote:You can find it locally. And you can have my 3 QTS if you want it. I picked mine up at http://www.3rauto.com/
Sold. pm inbound!
Postby RX-7 Chris » Tue Dec 20, 2011 9:14
on a fwd you can't add the fluid through the shifter.
RX-7 Chris wrote:on a fwd you can't add the fluid through the shifter.
No problem, I'm gonna use your pump when we swap in the STS :D
Postby Shadowden » Tue Mar 13, 2012 9:14
I'm a slacker...still need to do this.
edit:
Not a very difficult task. It would have been a little more awkward with te car only on jackstands, but not difficult still. I changed mine at 75k. The 2-3 shifts now have no clunk to them. I also used the Redline MT90. Thanks to Huzer, I only needed to buy 1 qt. Need to get one of my own pumps though. Seems like a good thing to do more often (every 30 k perhaps).
Users browsing this forum: No registered users and 6 guests
