Wtb Cobb AP mazdaspeed6
COspeed6
Postby COspeed6 » Fri Mar 30, 2012 9:14
Hey I'm looking for an unmarried Cobb AP for my 2007 speed6 I am willing to pay $400.
If you have one please contact me.
Thanks,
Dennis
303-482-5638
Mortose
Postby Mortose » Fri Mar 30, 2012 9:14
Have you checked over at MSF.org? If you donate you get access to there for sale section. Also, they have a ton of info on there.
And sorry to be a downer, but I doubt you will find one for less than 500.
Postby erod550 » Fri Mar 30, 2012 9:14
$450 shouldn't be too much of a problem. $400 will be a lot tougher.
COspeed6
When I first bought my car there were about 3 AP's on craigslist for $400, so I'm hoping I can find one around there.
COspeed6
Postby COspeed6 » Wed Apr 04, 2012 9:14
Found one for $400. Stage 1 is a fantastic improvement over stock!
Mortose
Postby Mortose » Wed Apr 04, 2012 9:14
WOOT! awesome man.
I know exactly how you feel!
Postby ~Barn~ » Wed Apr 04, 2012 9:14
Congrats. It's pretty much the best B4B upgrade ever.
Image 720.935.6438
COspeed6
The next thing I want to do is find a stock ms6 and gut it so I can go stage 2 while remaining stock looking. (I have an extended warranty and i don't want to remove the dp every time I go to the stealership.)
Postby erod550 » Thu Apr 05, 2012 9:14
~Barn~ wrote:Congrats. It's pretty much the best B4B upgrade ever.
Downpipe. Got mine for a little less than I paid for my AP and it made a way bigger difference than just the AP alone. But part of that could have been the new tune with the downpipe too so it was kind of a combination of AP and downpipe.
Postby ~Barn~ » Thu Apr 05, 2012 9:14
<------ Scared of the Downpipe.
Image 720.935.6438
COspeed6
Postby COspeed6 » Thu Apr 05, 2012 9:14
So am I! I've read that if I get a test/ race pipe I can go stage 2, is this true or false?
I ran Stage2 maps before I had the test pipe, and I was never out of spec with my critical metrics.
Image 720.935.6438
Mortose
Postby Mortose » Thu Apr 05, 2012 9:14
The reason you don't go to Stage 2 without an aftermarket DP/RP/TP, is that with higher boost temps and pressures, you can cook your stock Cat.
So, since you have internals, once you get a DP, by cobb's standards, you are good to go with stage 2.
So in that case, is it kosher to run Stage2 on a car that only has a Test Pipe, but not a Down Pipe? I mean.... that first cat is still there, post turbo. Image
Image 720.935.6438
Mortose
well, i would look at getting a DP, just to be safe.
Do you have internals/pump replacement?!
