Torque for Android
hcbr929rr2
Torque for Android
Just an FYI I just bought an OBDII bluetooth adapter and installed this program on my phone, its pretty nice, cheapest way there is to monitor Fuel pressure, the boost gauge seems off, I'm guessing its cause we are a mile high and barometric pressure is different up here, still gotta figure that one out, but for a total of $25.00 I can now monitor direct injection fuel pressure and air/fuel ratio, which seems to be the most important thing on our cars anyway
2012 Mustang GT 5.0 - Kona Blue
1991 Ford F-150 - Red
2004 Corvette Z06 - Torch Red
1988 Nissan 300ZX - Beater White
- I`m Batman
hcbr929rr2
yeah the only thing its missing is Kr, but you don't watch Direct Injection Fuel Pressure? and did you have to configure any kind of base barometric pressure so that it would read boost properly?
- I`m Batman
I have fuel pressure on a different screen. I figured if the fuel pressure drops, my KR (which I'm monitoring) would go crazy so I would see it either way, so it's kind of related. But I choose to display KR because... say if the boost temp is too high, you'll get KR too, so I would take it easy until I can get the boost temp to go down.
hcbr929rr2
hcbr929rr2 wrote:the boost gauge seems off, I'm guessing its cause we are a mile high and barometric pressure is different up here, still gotta figure that one out
yup, that's normal. Should see between 10-13 psi on the gen 1's (I think Gen 2 is the same boost too). At sea-level it's 15-18psi. Sucks for us
Make sure you're looking at DI Pressure, not normal fuel pressure.
hcbr929rr2
yeah the boost thing sucks, I'm watching fuel rail pressure though, which seems to be DI pressure, under WOT it sits around 1700 +/- 50, I've been watching A/F Ratio too, under WOT it sits at about 11.8:1, so everything is looking pretty kosher
mOOsE wrote:yup, that's normal. Should see between 10-13 psi on the gen 1's (I think Gen 2 is the same boost too). At sea-level it's 15-18psi. Sucks for us
Agreed. My car pulled much harder when I lived on the east coast....
Users browsing this forum: Bing [Bot] and 178 guests
