MAzda3 Engine Sources
Postby Shadowden » Thu Jun 28, 2012 9:14
So I know there are quite a few places to buy jdm Honda and Acura engines, but I'm in need of a Mazda engine. My 2005 MZ3 now has "rod knock", which requires either rebuilding the bottom end, or aswapping out for a remanufactured engine. I had some oil consumption issues in my car, which I'm sure led to the rod problem.
Having said that, I'm hoping some others have found good sources for quality Mazda 3 engines.
Thanks for any help in advance.
Postby erod550 » Thu Jun 28, 2012 9:14
Postby I`m Batman » Thu Jun 28, 2012 9:14
Junk yard, mebby?
Postby kingtut » Thu Jun 28, 2012 9:14
At what point does new car shoppong come into affect?
Postby tsx_guy » Thu Jun 28, 2012 9:14
why not honda? a nice k20 or k24 in there. wheee!!!
tsx_guy wrote:why not honda? a nice k20 or k24 in there. wheee!!!
naw, you gotz ta get da B16b with B18 bottom end yo! Slam that chiet and put a coffee can muffler on there and put some 14" steelies up front and 20" in the back!
And don't forget ta hook it up wid some NAAAAAAAAWWWWWWWSSSSSSS!!!!!
kingtut wrote:At what point does new car shoppong come into affect?
When the new car is less than an engine?
Thanks EROD. I'm not sure if I want a donor engine. I was thinking remanufactured. I realize it came from a donor, but it has been gone over and generally has a warranty of sorts. The ones I found last night were all pretty high mileage, but not sure if that is a concern if they have been redone.
Also, I actually need a 2.3L engine. I forget that the 2.0L exists.
ooh ooh, put a rotary in der.
I`m Batman wrote:naw, you gotz ta get da B16b with B18 bottom end yo! Slam that chiet and put a coffee can muffler on there and put some 14" steelies up front and 20" in the back!
I give you a thumbs down here sir... this post was no help, i repeat no help at all. (rotates 14" to rear of fwd car....)
I should have held out for a cleaner eg...this Mazda stuff is ridiculous.:mellow:
Well if you're not willing to take a used engine and only a remanufactured one, then you're actually getting close to the cost of another used car. Especially if you don't have the tools/knowledge to put it in yourself.
http://www.powertrainproducts.net/Mazda-2-3-engine-03-05-3-6-models-p/2071.htm
tsx_guy wrote: (rotates 14" to rear of fwd car....)
I see the small steelies(pretending to be race/drag slicks) in the front all the time and big wheels in the back. They're hardcore drag racer cars... don't you know? :lol:
Anyway, back on topic... ya, like erod said, if you want reman engine and you're not putting in yourself, it's going to be pretty pricey with labor cost. Unless you really love your car and want to keep it, then it doesn't matter.
I have someone willing to help me install the engine.
Thanks for finding that one erod. I prefer a remanufactured, because it should be as close to a new engine as you can get. A used one might have me in the same place in a short time. Might it be worth it if it holds up, you betcha, but the time and labor involved, as well as the inconvenience is pretty high. I realize I could have the same issues with a reman, I just think it is less likely (definately could be wrong).
a 4 year warranty is pretty solid.
Its not so much that I love the car, its more that I don't have 10k sitting around for another used car since I bought this one less than a year ago. And I actually have no idea what I want for my next car. I'm not closing my options completely. Just not able to think clearly about what I want to do exactly.
Users browsing this forum: Baidu [Spider] and 142 guests
