Another FD in the area
JTurton7
Re: Another FD in the area
Postby JTurton7 » Tue May 26, 2015 9:14
Yeah, I would definitely appreciate help tuning. I'm in the final stretch of finishing everything so hopefully I can do some Auto-X/Time Attack/Drifting this summer.
JTurton7
This summer we all need to have a friendly RX7 PPIR time attach competition :)
lOOkatme
Postby lOOkatme » Wed May 27, 2015 9:14
I have time this weekend if you want to tune the car.
JTurton7
Postby JTurton7 » Wed May 27, 2015 9:14
I'm finishing up the brake bias valve relocation and catch can/hard lines then ill be ready to tune hopefully. That and the new ignition setup should fix all of the weaknesses I found trying to tune it last time.
Postby RX-7 Chris » Wed Jun 03, 2015 9:14
I like the look of option 1 better.
JTurton7
Postby JTurton7 » Sat Jun 06, 2015 9:14
Here is where I ended up putting it. Could have done a better job but metal lines are hard to work with in tight spaces.
Ignition in and brakes all done. (need to bleed them)
Next item on the list is on hold while I wait for the -10 hardline to show up, its on back order. Gonna need to weld an aluminum bar here to mount the catch can.
With any luck this will fix the issues that arose during tuning.
JTurton7
Postby JTurton7 » Mon Jun 08, 2015 9:14
Drove the car today. WOW. There is noticeably more low rpm torque available with this ignition setup. 180k mile stockers vs new upgraded coils.
JTurton7
Postby JTurton7 » Wed Jun 10, 2015 9:14
Hit a bunny, ordered a sticker....
Postby Shadowden » Wed Jun 10, 2015 9:14
Bandaid sticker?
Postby speedjunkie » Fri Jun 12, 2015 9:14
JTurton7 wrote:Drove the car today. WOW. There is noticeably more low rpm torque available with this ignition setup. 180k mile stockers vs new upgraded coils.
Damn, now I'm really gonna have to get the bigger turbo. I already have too much down low and it's only going to get better (or worse?). lol As soon as I get my car back we need to swap for test drives.
Did you get ahold of Mitch? I gave him your number too.
Saul_Good
Postby Saul_Good » Fri Jun 12, 2015 9:14
I vote for laptimes :P
JTurton7
Postby JTurton7 » Sun Jun 14, 2015 9:14
Yup Mitch welded the mount on yesterday. I need to pick up a pipe bender and finish up the hardlines today. My first attempt at bending it on my leg had less then desirable results haha.
Postby speedjunkie » Sun Jun 14, 2015 9:14
I have a bending tool also lol.
JTurton7
hahaha, Im done with your flare tool. You gonna be at work tomorrow? I can drop it off.
JTurton7
Postby JTurton7 » Tue Jun 16, 2015 9:14
flange not notched properly to fit = bad oil leak near exhaust. Im a baddie
modified to fit properly = good, no leaks. Now I get to clean up another oil mess...
Users browsing this forum: No registered users and 104 guests
