New Goodies!
Postby Huzer21 » Fri Oct 12, 2007 9:14
<div class='quotetop'>QUOTE (arctic_blue83 @ Oct 12 2007, 09:29 AM) [url=index.php?act=findpost&pid=4906]<{POST_SNAPBACK}>[/url]</div>
Must.... have.... impressions.... we should really have a mountain drive meet, maybe a quick spin up to Lookout Mountain?!? The RX-8 isn't exactly at home on the drag strip, but it sure as hell has the power to surprise when roads get twistie.
Couple questions man, what kind of tires are you running? Are you going to attempt driving the RX-8 this winter? Also, what was the diameter of the stock bars and what's the diameter of the RB bars?[/b]
I plan on going for a drive either today or tomorrow AM. Initial impressions, and this isn't at any type of speed or anything, is that the car definitely doesn't roll through the turns as much as it used to. Granted, the RX-8 doesn't roll much to begin with, but these bars come close to eliminating that. The front bar is very hefty, 32mm, and a .1875" wall vs 27mm and a .134" wall. The rear is 19mm vs 16mm diameter, and is a straight bar, the stock bar has a couple of angles in it. I snapped some pictures that I haven't uploaded yet.
I tried to get decent speed on my off ramp, only to have to scrub off some speed quickly when an oversized delivery truck was lumbering around the corner. I thought I had enough room, but they were only going about 20. Steering input seems slightly sharper, and the car overall just stays planted. Very pleased with the results. The RX-8 handles great to start with, so this just added to that.
Tires are Fuzion ZR1 235/40/18s. They seem ok, nothing special. I'll probably drive it on a limited basis in the winter. I can walk to work, so I won't need it for that. My plan at this point is to drive as little as possible, which won't be hard as I've only put on 900 miles since I bought the car. I'm definitely game for a mountain drive.
arctic_blue83
Postby arctic_blue83 » Fri Oct 12, 2007 9:14
Wow, a 5mm & 3mm difference in bars should make a VERY noticeable difference, that's awesome! For a street car, sway bars are one of the best suspension mods you can make without sacrificing ride/drivability... I was really sad when I realized on my former Speed6, you can only swap out front and rear bars to bars that were only 1mm larger (25mm vs 24mm and 24mm vs 23mm) due to clearance issues (especially the rear bar, as it's almost touching the rear diff lol). You'll have to take me for a ride sometime.
<div class='quotetop'>QUOTE (arctic_blue83 @ Oct 12 2007, 10:49 AM) [url=index.php?act=findpost&pid=4946]<{POST_SNAPBACK}>[/url]</div>
Wow, a 5mm & 3mm difference in bars should make a VERY noticeable difference, that's awesome! For a street car, sway bars are one of the best suspension mods you can make without sacrificing ride/drivability... I was really sad when I realized on my former Speed6, you can only swap out front and rear bars to bars that were only 1mm larger (25mm vs 24mm and 24mm vs 23mm) due to clearance issues (especially the rear bar, as it's almost touching the rear diff lol). You'll have to take me for a ride sometime.[/b]
That's the reason I went with the RB bars. The MS ones didn't seem like they'd be enough of a difference to justify the extra cost. Anytime you want a ride, lemme know. I work a fairly normal 7-4 M-F schedule. Weekend work only happens when I'm on call.
arctic_blue83
Dude you're more than welcome to stop by tonight for my GF's b-day party, although I might have a slight buzz by the time you get here lol.
<div class='quotetop'>QUOTE (arctic_blue83 @ Oct 12 2007, 02:02 PM) [url=index.php?act=findpost&pid=5011]<{POST_SNAPBACK}>[/url]</div>
Dude you're more than welcome to stop by tonight for my GF's b-day party, although I might have a slight buzz by the time you get here lol.[/b]
Fire off your address to me. I may swing by!
Postby MazdaTom » Fri Oct 12, 2007 9:14
Here's some good nerdy reading about sway bars:
http://www.teamscr.com/sway.html
The numbers they use are specific to Saturn, but the overall idea can be appealed across the board. I believe this article has appeared in a magazine a time or two.
arctic_blue83
<div class='quotetop'>QUOTE (Huzer21 @ Oct 12 2007, 02:03 PM) [url=index.php?act=findpost&pid=5012]<{POST_SNAPBACK}>[/url]</div>
Fire off your address to me. I may swing by![/b]
Just PM'd you my address [img]http://coloradomazdaclub.com/forums/style_emoticons/<#EMO_DIR#>/smile.gif[/img]
Users browsing this forum: Google [Bot] and 99 guests
