WTB - Speed3 exhaust
Postby bellalyssa » Sun Aug 16, 2009 9:14
I want to add a bit of a deeper sound to my Mazda and with the plans of putting in a turbo, I need an exhaust that can handle it. If you have an exhaust from a Speed3 that you're willing to part with let me know!
Eclipse
Postby Eclipse » Sun Aug 16, 2009 9:14
Unless you have the turbo, manifold, downpipe, and other more important parts sitting on the work bench already, I wouldn't worry about an exhaust yet. The GT28 setup will have to be custom, and alot of fabrication work will need to be done, including the downpipe, manifold, wastegate AND exhaust. A stock speed3 exhaust will be less than favorable for your future setup.., not saying it cant be done, but it will be very difficult. The downpipe location on the speed3 is not even close to the location on your car..
Powerstroke 6.0
Cesaros
Postby Cesaros » Sun Aug 16, 2009 9:14
get a custom exhaust or go with an F2 exhaust...MS3 exhaust is not worth it...and youll still be running emissions instead of catless...which is what you should shoot for.
my f2 was $385, runs catless, and comes with a race pipe....oh and it sounds better than the MS3 exhaust.
Where did you get your f2? I was under the impression that I should shoot for a Speed3 exhaust but I must have read something wrong.
Cesaros
with the speed3 exhaust...your still using a stock type exhaust...it still has the catalytic converters which will rob possible performance. with the speed3 exhaust your only getting a sound mod, no real performance gain. IMO I don't see the point in going from a stock exhaust...to a larger stock exhaust. It makes more sense to get an exhaust made for your car that was made to improve performance and sound, and remove some excess weight.
http://www.f2usa.com/138/index.php?main_page=product_info&cPath=3_107_110_208&products_id=275
this and the HKS Hi Power exhausts are IMO the best for the NA mazda3. a complete straight through design with a muffler.
If your ever interested in hearing mine and I'm gona be down in Northern Colorado, Id be happy to give u a demonstration.
I'm not trying to discourage you from getting another stock exhaust...just informing you that its not the best choice for your car. But if you do end up getting one, at least it will sound good.
T-time
Postby T-time » Mon Aug 17, 2009 9:14
f2 ftmfw
