system
pst4life
system
Postby pst4life » Mon Nov 16, 2009 9:14
does anybody know how much it will cost too insatall subs and an amp in too a factort head unit?
Eclipse
Postby Eclipse » Mon Nov 16, 2009 9:14
I can wire it up...for a case of beer
Powerstroke 6.0
pst4life
ok what do i need to get too have it installed
Eclipse
what do you have for a head unit? Amp, Subs?
Powerstroke 6.0
Postby dommo_g » Mon Nov 16, 2009 9:14
*factory head unit.
If your amp doesn't have speaker level inputs, you'll need a line level converter.
pst4life
Postby pst4life » Tue Nov 17, 2009 9:14
a what and i do not know
pst4life
i have the amp and subs in a box
Operator
Postby Operator » Tue Nov 17, 2009 9:14
Adding amplifiers to the factory system, you will need to use a LOC (line output convertor) or have an amplifier that has high level inputs.
An LOC is installed like a speaker. It then outputs RCAs for your amps. The sound must be full range to work correctly.
High level just needs a full range or high pass input, and it converts the signal inside. No need to run RCAs since the high level input is directly in the amp.
http://www.davidnavone.com makes the best LOCs.
And an AMP kit. If ya want to go cheap, get one from wal-mart......
JL 1000/1 - JL 450/4
[/font]
Current:
pst4life
Postby pst4life » Wed Nov 18, 2009 9:14
ok i guess i'm confused on what you just told me i'm not a electrical person
Postby dommo_g » Sat Nov 21, 2009 9:14
If you can't understand any of that, you need to just take your car to a shop. Nobody here can give you the price some place is going to charge you, unless someone here happens to work at a shop. Just take it to Quality Auto Sound or something like that and be done with it.
pst4life
Postby pst4life » Sat Nov 21, 2009 9:14
i know how too install a system with an aftermarket radio but not with a stock one
Postby dommo_g » Sun Nov 22, 2009 9:14
pst4life
Postby pst4life » Sun Nov 22, 2009 9:14
whatever you ass i was just asking a question
Postby TheNewBlack » Sun Nov 22, 2009 9:14
pst4life wrote:whatever you ass i was just asking a question
....and he answered it. Twice.
memphis
Postby memphis » Sun Nov 22, 2009 9:14
ok, this is my suggestion to you.. since you say you know how to install it all but the stock radio part.. then install everything,, SUBS, AMPS, run all your power wires and RCA's .. basically have it all in there so you can just take it to a shop and have them ONLY install the LOC for you and they shouldnt charge you to much to do it.. OR,, you could do all that, then go down to the shop and play it cool.. Tell them what your wanting to do and they will guide you in the right direction and maybe even give you some advice and tips on how you can do it yourself.
